[GRASS-user] i.maxlik
Hello,
I am running i.maxlik in python - attempting to automate a processing chain.
I use the command:
grass.run_command(‘i.maxlik’, group= group, subgroup=subgroup, class=‘classification’, sigfile = sigfile, verbose = True)
Infuriatingly, however ‘class’ is a python keyword and it doesn’t run due to ‘invalid syntax’.
Would you know a way to work around this?
Regards
Becky
On Wed, Feb 13, 2013 at 10:50 AM, Margherita Di Leo <diregola@gmail.com> wrote:
On Wed, Feb 13, 2013 at 10:36 AM, Rebecca Stedham <rlstedham@btinternet.com> wrote:
Hello,
I use the command:
yes there is a workaround, although not recommended, more or less sounds like:
import os
os.system(“i.maxlik group=group subgroup=subgroup class’classification’ sigfile=sigfile --v”)
BTW I would suggest to report the issue in the trac, in order to prevent the use of reserved python keywords in the modules.
madi
Regards
Becky
grass-user mailing list
grass-user@lists.osgeo.org
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Margherita DI LEO
Via Fermi, 2749
Hi
Hello,
I use the command:
grass.run_command('i.maxlik', group= group, subgroup=subgroup,
class='classification', sigfile = sigfile, verbose = True)
Infuriatingly, however 'class' is a python keyword and it doesn't run due to
'invalid syntax'.
I had a similar issue with v.distance which uses 'from', another python keyword.
Here the pythoncode is '_from' which looks like:
grass.run_command("v.distance",_from="xxx",to="xxx",...)
Maybe there is something similar for class ('_class'?) in i.maxlik.
/johannes
Regards
Becky
On Wed, Feb 13, 2013 at 12:27 PM, Johannes Radinger
<johannesradinger@gmail.com> wrote:
Hi
Hello,
I use the command:
'invalid syntax'.
Here a solution was suggested:
http://gis.stackexchange.com/questions/50753/is-there-a-workaround-for-grass-i-maxlik-class-being-a-keyword-in-python
Discussion to be continued in the grass-dev list, I have already
posted there.
