Hi?
I am trying to perform pansharpening on landsat raster, using pygrass. Below is the snippet
Kind Regards,
Joseph Kariuki
Geospatial Engineer | GIS / Web Developer
Hi?
Kind Regards,
Joseph Kariuki
ERROR: Raster map <LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux> not
found
just guessing, does
exist? is this the correct raster name?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321290.html
* Joseph Kariuki <joehene@gmail.com> [2017-05-22 13:35:44 +0300]:
Hi?
Not answering your question, but please give i.fusion.hpf a try.
Nikos
*n = 0for x in bluear:
mypansharpen.append(grass.run_command("i.pansharpen", red=redar[n],
green=greenar[n], blue=bluear[n], pan=panar[n],
output=bluear[n][0:21]+"pansharpen", method="ihs"))
n = n + 1*Running the code returns the following error
*ERROR: Raster map <LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux> not
found
File "/usr/local/grass-7.2.2svn/scripts/i.pansharpen", line 452, in <module>
main()
File "/usr/local/grass-7.2.2svn/scripts/i.pansharpen", line 119, in main
kv = grass.raster_info(map=pan)
File "/usr/local/grass-7.2.2svn/etc/python/grass/script/raster.py",
line 78, in raster_info
s = read_command('r.info <http://r.info>', flags='gre', map=map)
File "/usr/local/grass-7.2.2svn/etc/python/grass/script/core.py",
line 461, in read_command
return handle_errors(returncode, stdout, args, kwargs)
line 329, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['r.info
<http://r.info>', '-gre',
'map=LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux'] ended with
error
Process ended with non-zero return code 1. See errors in the (error) output.
File "/home/hempire/PycharmProjects/GRASSproject/landsatProcessing.py",
line 185, in <module>
line 410, in run_command
return handle_errors(returncode, returncode, args, kwargs)
grass.exceptions.CalledModuleError: Module run None ['i.pansharpen',
'blue=LE07_L1TP_166060_20030303_20170126_01_T1_B2',
'green=LE07_L1TP_166060_20030303_20170126_01_T1_B3',
'pan=LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux',
'output=LE07_L1TP_166060_2003pansharpen', 'method=ihs',
'red=LE07_L1TP_166060_20030303_20170126_01_T1_B4'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.*Note that I have also tried grass.read_command in place of
grass.run_command but still getting the same error output.Kind Regards,
*Joseph Kariuki*
*Geospatial Engineer** | **GIS / Web Developer*
grass-user mailing list
grass-user@lists.osgeo.org
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
[please keep it on the ML]
I just did a batch import of all raster bands including panchromatic band
therefor it exists.
found
it looks for => TIF.aux;
are you sure that this aux is a valid raster?
please post here the relevant part of g.list type=raster
and r.info-output for LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321300.html
I shall give it a try. thanks
On Mon, May 22, 2017 at 4:17 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
- Joseph Kariuki <joehene@gmail.com> [2017-05-22 13:35:44 +0300]:
Hi?
Below is the snippetNot answering your question, but please give i.fusion.hpf a try.
Nikos
mypansharpen.append(grass.run_command(“i.pansharpen”, red=redar[n],
output=bluear[n][0:21]+“pansharpen”, method=“ihs”))
n = n + 1Running the code returns the following error
found
File “/usr/local/grass-7.2.2svn/scripts/i.pansharpen”, line 452, in
main()
File “/usr/local/grass-7.2.2svn/scripts/i.pansharpen”, line 119, in main
File “/usr/local/grass-7.2.2svn/etc/python/grass/script/raster.py”,
s = read_command(‘r.info <http://r.info>’, flags=‘gre’, map=map)
File “/usr/local/grass-7.2.2svn/etc/python/grass/script/core.py”,
grass.exceptions.CalledModuleError: Module run None [‘r.info
<http://r.info>’, ‘-gre’,
‘map=LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux’] ended with
error
File “/home/hempire/PycharmProjects/GRASSproject/landsatProcessing.py”,
line 185, in
grass.exceptions.CalledModuleError: Module run None [‘i.pansharpen’,
‘blue=LE07_L1TP_166060_20030303_20170126_01_T1_B2’,
‘green=LE07_L1TP_166060_20030303_20170126_01_T1_B3’,
‘pan=LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux’,
‘output=LE07_L1TP_166060_2003pansharpen’, ‘method=ihs’,
‘red=LE07_L1TP_166060_20030303_20170126_01_T1_B4’] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.Note that I have also tried grass.read_command in place of
Joseph Kariuki
Geospatial Engineer* | *GIS / Web Developer
https://lists.osgeo.org/mailman/listinfo/grass-user–
Kind Regards,
Joseph Kariuki
LE07_L1TP_166060_20030303_20170126_01_T1_B1
LE07_L1TP_166060_20030303_20170126_01_T1_B5
LE07_L1TP_166060_20030303_20170126_01_T1_B61
LE07_L1TP_166060_20030303_20170126_01_T1_B62
LE07_L1TP_166060_20030303_20170126_01_T1_B7
LE07_L1TP_166060_20030303_20170126_01_T1_B8
LE07_L1TP_166060_20030303_20170126_01_T1_BQA
LE07_L1TP_166060_2003composite
LE07_L1TP_166060_20161016_20161111_01_T1_B1
LE07_L1TP_166060_20161016_20161111_01_T1_B2
LE07_L1TP_166060_20161016_20161111_01_T1_B3
LE07_L1TP_166060_20161016_20161111_01_T1_B4
LE07_L1TP_166060_20161016_20161111_01_T1_B5
LE07_L1TP_166060_20161016_20161111_01_T1_B61
LE07_L1TP_166060_20161016_20161111_01_T1_B62
LE07_L1TP_166060_20161016_20161111_01_T1_B7
LE07_L1TP_166060_20161016_20161111_01_T1_BQA
LE07_L1TP_166060_2016composite
therefor it exists.ERROR: Raster map <LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux> not
foundit looks for => TIF.aux;
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321300.html
Kind Regards,
Joseph Kariuki
and
not
found
your script is looking for
but it isn't in the g.list output.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321306.html
what does
r.info map=LE07_L1TP_166060_20161016_20161111_01_T1_B8.TIF.aux
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321309.html
found
If so how do I import a .aux file yet it is not among extensions supported by r.in.gdal command
On Mon, May 22, 2017 at 4:43 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
what does
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321309.html
Kind Regards,
Joseph Kariuki
ERROR: Raster map
not
foundIf so how do I import a .aux file yet it is not among extensions supported
have a look into the geotiff format:
http://www.gdal.org/frmt_gtiff.html
aux.xml-files are:
"PAM (Persitant Auxiliary metadata) .aux.xml sidecar file"
there is no need to import .aux.xml-files as these files only cover
metadata, not raster data.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321313.html
Ok. I am trying to understand why i.pansharpen is looking for that .aux.xml file
ERROR: Raster map
not
by r.in.gdal commandhave a look into the geotiff format:
aux.xml-files are:
“PAM (Persitant Auxiliary metadata) .aux.xml sidecar file”
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/i-pansharpen-error-tp5321277p5321313.html
Kind Regards,
Joseph Kariuki
.aux.xml file
It's not i.pansharpen, it's your script:
It seems to me that the aux file must have gotten into your panar list...
Moritz
