Hi list,
i am processing plenty of modis subsets into a group called “pca”
when using WinGRASS it gives an error
GRASS 7.0.svn> i.pca --overwrite input=pca output_prefix=_msub
Computing covariance matrix…
100%
ERROR: No non-null values
GRASS 7.0.svn>
can anybody help please?
Martin
On Fri, Apr 4, 2014 at 1:47 PM, Martin van Brakel
<m.l.vanbrakel@gmail.com> wrote:
Hi list,
i am processing plenty of modis subsets into a group called "pca"
Computing covariance matrix...
100%
GRASS 7.0.svn>
Did you set the computational region to the map beforehand?
g.region rast=pca -p
then
i.pca ...
See also:
http://grasswiki.osgeo.org/wiki/Computational_region
Since we currently have issues on the server (slow), see also the wiki
mirror at:
http://grass.fsv.cvut.cz/wiki-mirror/index.php/Computational_region
hope this helps
that helps but it breaks there…
100%
Calculating principal components…
100%
Rescaling to range 0,255…
100%
Eigen values, (vectors), and [percent importance]:
GRASS 7.0.svn>
Hi list,
100%
GRASS 7.0.svn>
then
i.pca …
See also:
mirror at:
hope this helps
On Fri, Apr 4, 2014 at 2:43 PM, Martin van Brakel
that helps but it breaks there...
100%
Calculating principal components...
100%
Rescaling to range 0,255...
100%
GRASS 7.0.svn>
Please try (just for fun) to not use the leading "_" in the prefix parameter.
Please also post the output of
g.version -g
The problem appeared to be the extent and the pixel resolution, g.region rast=file solved it, thanks
Martin
100%
100%
100%
GRASS 7.0.svn>
Please try (just for fun) to not use the leading “_” in the prefix parameter.
g.version -g
