[GRASS-user] i.pca with multiple input bands
Hi there
Is there any way to specify multiple input bands to i.pca? I'm working with
aviris data which has 224 bands and it'd be a disaster having to put each
band like
i.pca input=band1@PERMANENT,band2@PERMANENT, ..., band224@PERMANENT
I tried input=band*@PERMANENT and it doesn't work.
Thanks a lot.
View this message in context: http://n2.nabble.com/i-pca-with-multiple-input-bands-tp4046561p4046561.html
2009/11/22 pdu <du@cs.utk.edu>:
input=`g.mlist type=rast pattern=band*`
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Sun, Nov 22, 2009 at 4:39 PM, Martin Landa <landa.martin@gmail.com> wrote:
Small correction (add sep=","):
i.pca input=`g.mlist type=rast pattern=band* sep=","` out=...
otherwise the list won't be properly comma separated.
Thanks Martin. It works!
Peng
Martin Landa [via OSGeo.org] wrote:
2009/11/22 pdu <[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4046562&i=0>>:
i.pca input=band1@PERMANENT,band2@PERMANENT, …, band224@PERMANENT
input=g.mlist type=rast pattern=band*
Martin
<http://gama.fsv.cvut.cz/%7Elanda>
grass-user mailing list
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4046562&i=1>
View message @
http://n2.nabble.com/i-pca-with-multiple-input-bands-tp4046561p4046562.html
To unsubscribe from i.pca with multiple input bands, click here
View this message in context: Re: [GRASS-user] i.pca with multiple input bands
On Sun, 2009-11-22 at 07:38 -0800, pdu wrote:
Hi there
band like
Thanks a lot.
I was messing around for quite some time with i.pca but never tried with
so many "bands". Does this really work for you (224 bands)?
Thanks, Nikos
