[GRASS-user] i.pca with scrips
Dear Grass users
I am trying to run the principal components analysis with "i.pca" for 12
raster.
I made a script to process three times the "i.pca" with three sets
(twelve raster by each sets) of different parameters (temperature,
chlorophyll, Insolation), but when I run the scripts this only takes 11
images by sets. I tried i.pc manually and this takes twelve raster
correctly. Thank you in advance.
EXAMPLES WHIT SCRIP:
GRASS 6.4.1 > i.pca_.sh
Computing means for band 11...
100%
Computing row 1 (of 11) of covariance matrix...
EXAMPLES MANUALLY FOR ONE SET:
GRASS 6.4.1 >
input=tmedia_1,tmedia_2,tmedia_3,tmedia_4,tmedia_5,tmedia_6,tmedia_7,tmedia_8,tmedia_9,tmedia_10,tmedia_11,tmedia_12 output=PCA_tmedia_
Computing means for band 12...
100%
Computing row 1 (of 12) of covariance matrix...
EXAMPLE SCRIPS
#!/bin/bash
# Analisis de componentes principales
for map in tmedia_ aston_ clor_
do
B1=1
B2=2
B3=3
B4=4
B5=5
B5=6
B7=7
B8=8
B9=9
B10=10
B11=11
B12=12
i.pca rescale=0,0 input="$map$B1,$map$B2,$map$B3,$map$B4,$map$B5,$map
$B7,$map$B8,$map$B9,$map$B10,$map$B11,$map$B12" output=PCA_$map
On Mon, Jul 4, 2011 at 8:43 PM, Gaspar <gos47@hotmail.com> wrote:
Dear Grass users
raster.
100%
GRASS 6.4.1 >
100%
EXAMPLE SCRIPS
#!/bin/bash
do
B1=1
B2=2
B3=3
B4=4
B5=5
B5=6
B7=7
B8=8
B9=9
B10=10
B11=11
B12=12
Is $map$B6 really missing in the script or is it just a typo above?
I had a fatal error when writing the script, I omitted the B6 = 6 and
$map$B6, and B5=6 is bad. I fixed the script. The script is now working
perfectly. Another question: Your I could suggest improvements to the
scripts, to make it more compact: for example, you can use "*" instead
B1=1 B2=2 B3=3 etc.
Thanks Markus Metz
# SCRIPS GOOD EXAMPLE:
#!/bin/bash
do
B1=1
B2=2
B3=3
B4=4
B5=5
B6=6
B7=7
B8=8
B9=9
B10=10
B11=11
B12=12
$B6,$map$B7,$map$B8,$map$B9,$map$B10,$map$B11,$map$B12" output=PCA_$map
> Dear Grass users
> raster.
> 100%
> GRASS 6.4.1 >
> 100%
> EXAMPLE SCRIPS
> #!/bin/bash
> do
> B1=1
> B2=2
> B3=3
> B4=4
> B5=5
> B5=6
> B7=7
> B8=8
> B9=9
> B10=10
> B11=11
> B12=12
