(Mon Jan 30 22:57:31 2012)
g.extension -s extension=i.pr
svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
/GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <i.pr> from GRASS-Addons SVN (be patient)...
A i.pr/i.pr_subsets
A i.pr/i.pr_subsets/main.c
A i.pr/i.pr_subsets/Makefile
A i.pr/i.pr_subsets/old
A i.pr/i.pr_features_selection/Makefile
A i.pr/Makefile
Estratta revisione 50573.
Compiling <i.pr>...
/usr/lib/grass64/include/Make/Grass.make:418: attenzione:
sovrascrittura dei comandi per l'obiettivo "/home/gab/stage_
master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-
laptop/30962.0/dist.x86_64/bin"
/usr/lib/grass64/include/Make/Grass.make:409: attenzione:
comandi obsoleti per l'obiettivo "/home/gab/stage_master/GRA
laptop/30962.0/dist.x86_64/bin" ignorati
mkdir -p
/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0c
entropy.c
gcc '-I/usr/lib/grass64/include' '-I/home/gab/.grass6/addons/include'
'-I/home/gab/stage_master
/bin/sh: /usr/lib/grass64/tools/mkhtml.sh: not found
make htmlcmd
make[2]: ingresso nella directory
"/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/i.pr/i.pr_blob"
sh: Can't open
/build/buildd/grass-6.4.1/tools/g.html2man/g.html2man
make[5]: *** [/home/gab/stage_master/GRASSDATA/utm_wgs84/dot
laptop/30962.0/dist.x86_64/man/man1/i.pr.features.1] Errore
127
make[4]: *** [mancmd] Errore 2
make[3]: *** [cmd] Errore 2
make[5]: ingresso nella directory
mkdir -p
/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/dist.x86_64/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.1 sh
/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/dist.x86_64/docs/html/i.pr.blob.html
/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/dist.x86_64/man/man1/i.pr.blob.1
1
make[5]: uscita dalla directory
make[4]: uscita dalla directory
make[3]: uscita dalla directory
i.pr_classify
"/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/i.pr/i.pr_features"
i.pr_features_additional
make[1]: uscita dalla directory
"/home/gab/stage_master/GRASSDATA/utm_wgs84/dottorato_bari/.tmp/gab-laptop/30962.0/i.pr"
(Mon Jan 30 22:57:50 2012) Comando terminato (18 sec)
At this point I tried to compile GRASS 6.5 and then I wanted to install i.pr
but ... #configure
sudo CFLAGS="-g -Wall" ./configure --prefix=/usr/local/src/grass6_devel
--with-cxx --with-python --with-widgets --with-wxwidgets
--with-freetype=yes --with-ffmpeg=yes --with-postgres=yes --with-sqlite
--with-motif=no --with-glw=no --enable-largefile=yes
--with-freetype-includes=/usr/include/freetype2
--with-postgres-includes=/usr/include/postgresql
--with-opengl-libs=/usr/include/GL --with-proj-share=/usr/share/proj
--without-fftw --without-ffmpeg --with-readline=no
--with-tcltk-includes=/usr/include/tcl8.5/ --with-gdal --enable-64bit
...and
checking whether to use Tcl/Tk... yes
checking for location of Tcl/Tk includes... /usr/include/tcl8.5/
configure: error: *** Tcl/Tk includes directory /usr/include/tcl8.5/ does
not exist.
tcl8.5 is in /usr/share/tcltk/tcl8.5/ I have also tried: sudo ln -s
/usr/share/tcltk/tcl8.5/ /usr/include/
On Mon, Jan 30, 2012 at 11:16 PM, Gabriele N. <gis.gn@libero.it> wrote:
Ciao.
I have installed GRASS (6.4.1) from the repository and I can not install
i.pr (add-on).
With g.extension
... unfortunately 6.4.1 is too old in a sense that on Ubuntu problems are
known. They have been resolved (hopefully) since then in SVN and will
be official in 6.4.2 (or use already the current 6.4.svn).
On Mon, Jan 30, 2012 at 11:16 PM, Gabriele N. <gis.gn@> wrote:
Ciao.
i.pr (add-on).
With g.extension
At this point, I have to compile GRASS, and then install i.pr. .... but I
have the other problem:
but ... #configure
...and
not exist.
...and
/usr/include/tcl8.5/ does not exist.
you need to have the tcl8.5-dev package installed.
(search through the end of config.log to find the exact error)
just yesterday I updated the build instructions for debian/ubuntu,
maybe you could give them a try:
Thanks hamish.
I installed tcl8.5-dev and I followed this guide http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
and, although I got error ((Errors in:
/usr/local/src/grass6_devel/lib/ogsf
/usr/local/src/grass6_devel/lib/nviz
/usr/local/src/grass6_devel/misc/m.nviz.image
/usr/local/src/grass6_devel/visualization/nviz)) seems to work GRASS65.
I need i.pr. .. but still wrong. I have done:
cd /add-on/i.pr/
make MODULE_TOPDIR=/usr/local/src/grass6_devel/
PRLIB
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/PRLIB"
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/PRLIB"
i.pr_blob
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_blob"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_blob"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.blob.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.blob
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_blob"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.blob.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_blob"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_blob"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.blob.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.blob.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.blob.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_blob"
i.pr_classify
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_classify"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_classify"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.classify.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.classify
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_classify"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.classify.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_classify"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_classify"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.classify.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.classify.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.classify.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_classify"
i.pr_features
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_features"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_features"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.features
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_features"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_features"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_features"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_features"
"/home/gab/add-on/i.pr/i.pr_features_additional"
make htmlcmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_additional.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.features_additional
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_additional.html"
è aggiornato.
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_additional.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_additional.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_additional.1"
è aggiornato.
i.pr_features_extract
"/home/gab/add-on/i.pr/i.pr_features_extract"
make htmlcmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_extract.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.features_extract
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_extract.html"
è aggiornato.
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_extract.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_extract.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_extract.1"
è aggiornato.
"/home/gab/add-on/i.pr/i.pr_features_selection"
make htmlcmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_selection.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.features_selection
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_selection.html"
è aggiornato.
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_selection.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.features_selection.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.features_selection.1"
è aggiornato.
i.pr_model
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_model"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_model"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.model.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.model
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_model"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.model.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_model"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_model"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.model.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.model.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.model.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_model"
i.pr_statistics
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_statistics"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_statistics"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.statistics.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.statistics
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_statistics"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.statistics.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_statistics"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_statistics"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.statistics.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.statistics.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.statistics.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_statistics"
i.pr_subsets
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_subsets"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_subsets"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.subsets.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.subsets
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_subsets"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.subsets.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_subsets"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_subsets"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.subsets.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.subsets.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.subsets.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_subsets"
i.pr_training
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_training"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_training"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.training.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.training
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_training"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.training.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_training"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_training"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.training.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.training.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.training.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_training"
i.pr_uxb
make[1]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_uxb"
make htmlcmd
make[2]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_uxb"
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.uxb.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.uxb
make[3]: ingresso nella directory "/home/gab/add-on/i.pr/i.pr_uxb"
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.uxb.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_uxb"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_uxb"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.uxb.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.uxb.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.uxb.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_uxb"
i.pr_sites_aggregate
"/home/gab/add-on/i.pr/i.pr_sites_aggregate"
make htmlcmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.sites_aggregate.html
HTMLSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/i.pr.sites_aggregate
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.sites_aggregate.html"
è aggiornato.
make[3]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_sites_aggregate"
make[2]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_sites_aggregate"
make mancmd
make
/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.sites_aggregate.1
MANSRC=/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/docs/html/i.pr.sites_aggregate.html
make[3]:
"/usr/local/src/grass6_devel/dist.x86_64-unknown-linux-gnu/man/man1/i.pr.sites_aggregate.1"
è aggiornato.
make[1]: uscita dalla directory "/home/gab/add-on/i.pr/i.pr_sites_aggregate"
work GRASS65.
I think that wiki page was missing the libglu1-mesa-dev and libxmu-dev
package dependencies needed for nviz. (now fixed)
cd /add-on/i.pr/
Then I open grass65 but i.pr not exist
Why?
there is no "i.pr" module, but a lot of i.pr.* modules:
On Mon, Jan 30, 2012 at 11:16 PM, Gabriele N.<gis.gn@libero.it> wrote:
Ciao.
i.pr (add-on).
With g.extension
.... unfortunately 6.4.1 is too old in a sense that on Ubuntu problems are
does your build pull from the DebianGIS git build
rules daily too? (I tried to find the recipe on the
ppa with no luck)
since i.pr is a toolbox not a module, g.extension
does not handle it very well (yet). the build should
go ok, but some minor user cleanup of the final
install is required.
