hello,
I compiled i.pr from svn and when executing this command:
i.pr.training map=in_elev,in_land vis_map=in_elev training=ipr_training_test
rows=11 cols=11 class=2
Speicherzugriffsfehler
I get "memory access error".
I had a similar message using g.copy a while ago but it was solved with
make -C general/manage clean
make -C general/manage CFLAGS1='-g'
from the ML.
I did:
make distclean
export CVSROOT=:ext:martin@grasscvs:/grassrepository
export CVS_RSH=ssh
cvs update -dP grass6
cd grass6
sudo ./configure --with-tcltk-includes=/usr/include/tcl8.4 --with-postgres-includes=/usr/include/postgresql --with-gdal=/usr/local/bin/gdal-config --enable-largefile
make
-> errors for i.pr appear
# for i.pr:
make MODULE_TOPDIR=/home/wegmann/software/grass/grass6/
sudo make install
any idea where the error might be? TIA Martin
hi Martin,
I have updated the old GRASS 5 sites API to legacy GRASS 6 sites API for
i.pr.training. Not sure if that helps.
Check that you don't have an empty file ipr_training_test in the current
directory.
If it still fails, please
- post a gdb backtrace
- replicate it with Spearfish or the new North Carolina data set
Martin Wegmann wrote:
hello,
from the ML.
I did:
make distclean
export CVS_RSH=ssh
cd grass6
make
# for i.pr:
sudo make install
View this message in context: http://www.nabble.com/i.pr-memory-error-tf4297941.html#a12235867
On Monday 20 August 2007 15:21:25 Markus Neteler wrote:
hi Martin,
directory.
that was the problem
thanks - it is working now - but I have still to figure out how, because I
don't understand Italian.
cheers, Martin
> hello,
> from the ML.
> I did:
> make distclean
> export CVS_RSH=ssh
> cd grass6
> make
> # for i.pr:
> sudo make install
Martin Wegmann wrote on 08/20/2007 05:24 PM:
hi Martin,
directory.
I have added a test to catch this problem (please try).
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
>> hi Martin,
>> directory.
sorry, took a while to recompile the whole stuff.
Now I get this error message:
first run:
i.pr.training map=in_elev,in_land training=AAA3 rows=11 cols=11 class=1
vis_map=in_elev
second run:
vis_map=in_elev
ERROR: read_training-> Format not recognized
perhaps 'training="name" cannot be overwritten' otherwise i would thing that
something is wrong with AAA3 format.
BTW doing d.mon x0 and run i.pr.training shows a black monitor with some
explanation but without any raster file - hence vis_map= does not work but
the raster exists. Any idea how to solve that?
TIA, Martin
