[GRASS-user] i.rgb.his/i.his.rgb not working properly
I'm having some problems using i.rgb.his/i.his.rgb to convert quickbird data from RGB to IHS and vice versa (original purpose was pan sharpening). The results look totally weird and I don't know why.
Here is a protocol along with some screenshots:
[1] d.rgb r=szene1_mul.4 g=szene1_mul.3 b=szene1_mul.2
--> http://img96.imageshack.us/img96/9487/screen1i.png
[2] i.rgb.his r=szene1_mul.4 g=szene1_mul.3 b=szene1_mul.2 h=szene1_234.h i=szene1_234.i s=szene1_234.s
[3] d.his h=szene1_234.h i=szene1_234.i s=szene1_234.s
--> http://img35.imageshack.us/img35/6746/screen2pm.png
[4] i.his.rgb h=szene1_234.h i=szene1_234.i s=szene1_234.s r=szene1_234.r g=szene1_234.g b=szene1_234.b
[5] d.rgb r=szene1_234.r g=szene1_234.g b=szene1_234.b
--> http://img246.imageshack.us/img246/1856/screen3pa.png
I also repeated the process using landsat data from the nc data set - same problem here.
g.version
GRASS 6.4.0RC5 (2009)
Did anybody experience similar problems?
bests,
Georg
On Tue, Sep 29, 2009 at 3:26 PM, Georg Kaspar <georg@muenster.de> wrote:
are you sure about the channel order?
problem here.
ok, I have tried that, too:
g.region rast=lsat7_2002_10
d.mon x0
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
i.rgb.his b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
h=lsat7_2002_h i=lsat7_2002_i s=lsat7_2002_s
d.his h=lsat7_2002_h i=lsat7_2002_i s=lsat7_2002_s
-> result is some grey scale image.
Perhaps that's correct?
Find attached a RGB/HIS fusion script which I wrote some years ago:
# NC data set:
i.fusion.his b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
pan=lsat7_2002_80 prefix=fusion
g.region -p rast=fusion.red
d.mon x0
d.rgb r=fusion.red b=fusion.green g=fusion.blue
It may need some cosmetics to follow 6.4 coding standard but seems
yet to work.
cheers
(attachments)
i.fusion.his (3.78 KB)
...by the way: is there a build in possibility to convert lat-long
degree coordinates in time coordinates? (to change this in a table)
From decimal to sexagesimal, try this:
cat file.csv | cs2cs -f "%.8f" +proj=latlong +datum=WGS84 \
      +to +proj=latlong +datum=WGS84
cheers
...I just need the pure conversion from decimal to sexagesimal(;-)) to
convert the output of eg.:
v.to.db -p map=lines@achim option=start
, which is decimal to D:M:S in the table.
Is there something like cs2cs?
A
cheers
yes, it's a false color composite. i set the colortable to grey, so the
image looks a bit dull.
problem here.
d.mon x0
i converted the results back to rgb and it works. pansharpening was also
possible using channel 8.
unfortunately - it still doesn't work using quickbird data
thanks for the script. unfortunately the output looks still the same
since the script makes use of the same modules. does the script work on
your installation?
Georg Kaspar wrote:
  > i converted the results back to rgb and it works. pansharpening was also
It work's, though i had to rescale all channels to 8bit using r.mapcalc. Is it possible that 16bit are not supported by i.rgb.his/i.his.rgb in general?
Dear grass-users,
because I could not find something else, I write a little script to
convert lat/long decimal degrees to lat/long sexagesimal degrees
(deg:min:sec).
It works with a sqlite-database and sqlite3, t2sql.sh (to convert
text-file to a table) and awk (on all linux-systems).
Maybe someone will need this some day:
$1 table name (need a unique column "cat")
$2 column with decial-degrees
$3 column, where sexagesimal degrees will be written (can be same as $2)
$4 sqlite database-file
eg:
sh decimal_to_sexagesimal.sh table col_decimal col_sexag
/home/userneme/grass/databasefile
warning: its very modest and dont deal with execptions. (eg. overwrites
the files temp_decimal_input.txt and temp_sexagesimal_output.txt)
Achim
A
cheers
grass-user mailing list
grass-user@lists.osgeo.org
(attachments)
decimal_to_sexagesimal.sh (720 Bytes)
for the other direction there is m.proj -o (-d)
we should really add support in that to allow d:m:s input too,
Martin made some improvements in grass7, so maybe already works?
Hamish
ps- there was an old wish (in trac??) to have a variable set to
determine module DMS output format.
from gui/tcltk/gis.m/mapcanvas.tcl:
# FIXME: make this settable from the UI or use GRASS_DMS_FORMAT enviro var
# DMS format: 0 is ddd.dddddd, 1 is ddd:mm.mmmm', 2 is ddd:mm'ss.sss"
set dms_format 2
Hamish
set dms_format 2
yea, that would be the easiest way. Shouldnt be that complicated, to put
that option in v.to.db tool.
Wish I was capable to do that...
A.
general?
AFAICT, i.rgb.his requires that the data is 0-255.
