[GRASS-user] i.segment.hierarchical on windows?
hi,
anyone used i.segment.hierarchical in winGRASS7?
seems not to work here; GUI can't be opened
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091.html
On Tue, Dec 9, 2014 at 1:52 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
I'm just looking at the MS Windows build logs. There is the strange issue
which was discussed some time ago on grass-dev if I remember correctly.
    is not going to be frozen to produce a Windows executable.''')
RuntimeError:
            Attempt to start a new process before the current process
            has finished its bootstrapping phase.
And there is also:
  File
"c:\osgeo4w\usr\src\grass70_release\dist.i686-pc-mingw32\etc\python\grass\pygrass\raster\buffer.py",
line 8, in <module>
    FCELL = (np.float, np.float16, np.float32)
AttributeError: 'module' object has no attribute 'float16'
What is your error message if any? What about command line?
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0svn/logs/
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0svn/logs/i.segment.hierarchical.log
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
from the winGRASS-wxcommand line:
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\gui
_core\prompt.py", line 263, in OnItemSelected
self.cmdDesc = gtask.parse_interface(cmd)
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass
\script\task.py", line 509, in parse_interface
tree = etree.fromstring(get_interface_description(name))
\script\task.py", line 489, in get_interface_description
"\n\nDetails: %(det)s") % {'cmd': cmd, 'det':
decode(cmderr)}
grass.exceptions
ScriptError
Unable to fetch interface description for command
'i.segment.hierarchical'.
Details: C:\OSGeo4W\bin\python.exe: can't open file
'i.segment.hierarchical': [Errno 2] No such file or
directory
from the windows console:
C:\>i.segment.hierarchical
  File
"C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scripts/i.segment.hiera
rchical.py", line 146, in <module>
    from grass.pygrass.modules.grid import GridModule
  File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\modules\gri
d\__init__.py", line 2, in <module>
    from grass.pygrass.modules.grid.grid import GridModule
  File
d\grid.py", line 17, in <module>
    from grass.pygrass.modules.grid.patch import rpatch_map
  File
d\patch.py", line 10, in <module>
    from grass.pygrass.raster import RasterRow
  File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\raster\__in
it__.py", line 32, in <module>
    from grass.pygrass.raster.buffer import Buffer
  File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\raster\buff
er.py", line 8, in <module>
the same issue as in
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/logs/i.segment.hierarchical.log
some more issues:
- it seems the html manual is empty:
http://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.html
therefore g.extension claims an error
- there is a lib dependency:
http://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.segment.hierarchical/isegpatch.py
but the zip-file for winGRASS-g.extension
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/i.segment.hierarchical.zip
doesn't include isegpatch.py; therefore winGRASS-i.segment.hierarchical
can't find this dependency in e.g.
C:\Users\xxx\AppData\Roaming\GRASS7\addons\etc
maybe some make issue.
for errors mentioned above I've put all the addon files manually in
C:\Users\xxx\AppData\Roaming\GRASS7\addons accordingly and added a bat file.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091p5177120.html
And there is also:
File
\buffer.py", line 8, in <module>
C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\raster\buffer.py
line 7: CELL = (np.int, np.int0, np.int8, np.int16, np.int32, np.int64)
line 8: FCELL = (np.float, np.float16, np.float32)
line 9: _DCELL = 'float64', 'float128'
line 10: DCELL = tuple([getattr(np, attr) for attr in _DCELL if hasattr(np,
attr)])
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091p5177122.html
Hi Helmut,
Ok, this should be fix in r63462.
some more issues:
If I don't put an empty html file the make command give me an
error... Of course I should add some more details, but I didn't have
time for this.
I don't know how to fix this... you should have the same problem with
other modules that are using their own libraries like r.modis, aren't
you?
Best regards
Pietro
AFAIK float16 data type was introduced in NumPy 1.6, while OSGeo4W based
winGRASS uses 1.5.
time for this.
I've added a manual skeleton by r63463
(http://lists.osgeo.org/pipermail/grass-commit/2014-December/034373.html)
you?
I'll have a look.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091p5177184.html
you?
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/r.modis.zip ships a
folder and files in etc\r.modis.
maybe some inspiration for make file from there?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091p5177186.html
Hi Helmut,
winGRASS uses 1.5.
ok, now should be loaded only if available.
time for this.
Thanks! I will try to fill it with a small example.
Best regards
Pietro
