Hello list,
I am working on segmentation of aerial imagery in forest areas and have used both modules (i.segment and i.segment.gsoc) for some experiments.
When running i.segment and i.segment.gsoc with radioweight = 1 on the same dataset with a threshold of 0.3, I assumed the output should be similar, but it isn't.
In the manual of i.segment.gsoc it is stated that the threshold will be multiplied by the number of rasters in the image group, so I tried a threshold of 0.1 in i.segment.gsoc vs a threshold of 0.3 in i.segment as I have 3 rasters in my image group. Although the results are now more similar, they still vary a lot.
I have attached the images to show the derived segments from i.segment 0.3 and i.segment.gsoc 0.1. Can someone help me to understand why this is happening? I would appreciate it.
Kind regards,
Melanie Brauchler
(attachments)
i.segment.gsoc is the original version developed during GSoC. i.segment is ann optimized version that was originally based on the GSoC work, but has known different developments since, including in the way the threshold parameter is applied.
I would recommend using i.segment.
Moritz
Am 10. Juni 2020 13:13:33 MESZ schrieb mbrauchler@posteo.de:
Hello list,
as
Kind regards,
Melanie Brauchler
Thank you for the explanation! I assumed gsoc version is build upon i.segment.
Is there any way to include the shape parameters in i.segment? I am very fond of the gsoc version as it helps surpress segments growing to very complex geometries (shadows through the forest patches for example).
Kind regards,
Melanie
Moritz
Hello list,
similar, but it isn’t.
as
Kind regards,
Melanie Brauchler
There was some reasons why the shape parameters were not integrated in i.segment, but I can't remember why. Some code is actually there, but currently it is not used.
MarkusM, do you remember ? And how complicated would it be to integrate them ?
Moritz
Kind regards,
Melanie
On Jun 11, 2020 12:52 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Moritz
>Hello list,
have
experiments.
will be
>as
i.segment
this
>Kind regards,
>Melanie Brauchler
grass-user mailing list
grass-user@lists.osgeo.org
