[GRASS-user] i.spec.unmix module
Hi everyone
I saw that there is a module on spectral unmixing on the add-ons subversion repository, so, I downloaded and compiled the last grass 6.4 snapshot (grass-6.4.svn_src_snapshot_2008_06_14), download the addons with svn (svn checkout https://svn.osgeo.org/grass/grass-addons/ grass-addons). and compiled the module as described in the README I found on the addons (make MODULE_TOPDIR=/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14).
I got this messages:
/home/camilo/grass-addons/imagery/i.spec.unmix# make MODULE_TOPDIR=/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14
gcc -I/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:172: warning: passing argument 2 of ‘G_vector_norm_maxval’ makes integer from pointer without a cast
main.c:178: warning: passing argument 2 of ‘G_vector_norm_maxval’ makes integer from pointer without a cast
main.c:227: warning: assignment makes pointer from integer without a cast
main.c:231: error: expected expression before ‘[’ token
main.c:231: error: too few arguments to function ‘G_matrix_get_element’
main.c:231: error: ‘mat_struct’ has no member named ‘G_matrix_get_element’
main.c:235: error: expected expression before ‘[’ token
main.c:235: error: too few arguments to function ‘G_matrix_get_element’
main.c:262: warning: assignment makes pointer from integer without a cast
main.c:263: error: ‘mat_struct’ has no member named ‘m’
main.c:263: warning: assignment makes pointer from integer without a cast
main.c:264: error: ‘mat_struct’ has no member named ‘m’
main.c:264: warning: assignment makes pointer from integer without a cast
main.c:265: error: ‘mat_struct’ has no member named ‘n’
main.c:265: warning: assignment makes pointer from integer without a cast
main.c:266: error: ‘mat_struct’ has no member named ‘m’
main.c:266: error: ‘mat_struct’ has no member named ‘n’
main.c:266: warning: assignment makes pointer from integer without a cast
main.c:293: error: ‘mat_struct’ has no member named ‘m’
main.c:293: warning: assignment makes pointer from integer without a cast
main.c:295: error: ‘vec_struct’ has no member named ‘ve’
main.c:297: error: ‘vec_struct’ has no member named ‘ve’
main.c:306: error: ‘mat_struct’ has no member named ‘n’
main.c:307: error: ‘vec_struct’ has no member named ‘ve’
main.c:307: error: ‘mat_struct’ has no member named ‘n’
main.c:324: error: ‘mat_struct’ has no member named ‘n’
main.c:325: error: ‘vec_struct’ has no member named ‘ve’
main.c:326: error: ‘vec_struct’ has no member named ‘ve’
main.c:339: warning: assignment makes pointer from integer without a cast
main.c:349: error: ‘vec_struct’ has no member named ‘ve’
main.c:383:28: warning: missing terminating " character
main.c:383: error: missing terminating " character
main.c:384: error: expected ‘)’ before numeric constant
main.c:384: error: stray '' in program
main.c:385: error: stray '' in program
main.c:386: error: stray '' in program
main.c:387:11: warning: missing terminating " character
main.c:387: error: missing terminating " character
main.c:391: error: expected ‘;’ before ‘}’ token
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
I am using a debian server with Linux 2.6.22-3-686 #1 SMP Sun Feb 10 20:20:49 UTC 2008 i686 GNU/Linux
Is there any other way to compile this module? or is just that is under development?
Best
camilo
Pedro Camilo Alcántara Concepción
Department of Forest and Wildlife Ecology
Rm. 120 Russell Labs
1630 Linden Dr.
Madison WI 53706-1598
Phone +1/608/265-9219
http:/silvis.forest.wisc.edu
On Wed, 2008-06-18 at 08:30 -0500, Pedro Camilo Alcantara wrote:
Hi everyone
Camilo,
I get the same error as you under Ubuntu64 bit with grass-6.3.1svn
Nikos
Hi, as there has not been an answer on that matter I would like to ask again,
if someone can give an explanation on the i.spec.unmix AddOn problem with
grass64.svn, as I got exactly the same messages as quoted below.
Is it possible, that it has not yet been fitted with the sources of grass64?
And if so, what can I do to get i.spec.unmix running?
Best regards
Stefan
Hi everyone
subversion
gcc
-g -O2 -DPACKAGE=\""grassmods"\"
main.c: In function 'main':
main.c:172: warning: passing argument 2 of 'G_vector_norm_maxval' makes
main.c:178: warning: passing argument 2 of 'G_vector_norm_maxval' makes
main.c:231: error: expected expression before '[' token
main.c:231: error: too few arguments to function 'G_matrix_get_element'
main.c:231: error: 'mat_struct' has no member named 'G_matrix_get_element'
main.c:235: error: expected expression before '[' token
main.c:235: error: too few arguments to function 'G_matrix_get_element'
main.c:263: error: 'mat_struct' has no member named 'm'
main.c:264: error: 'mat_struct' has no member named 'm'
main.c:265: error: 'mat_struct' has no member named 'n'
main.c:266: error: 'mat_struct' has no member named 'm'
main.c:266: error: 'mat_struct' has no member named 'n'
main.c:293: error: 'mat_struct' has no member named 'm'
main.c:295: error: 'vec_struct' has no member named 've'
main.c:297: error: 'vec_struct' has no member named 've'
main.c:306: error: 'mat_struct' has no member named 'n'
main.c:307: error: 'vec_struct' has no member named 've'
main.c:307: error: 'mat_struct' has no member named 'n'
main.c:324: error: 'mat_struct' has no member named 'n'
main.c:325: error: 'vec_struct' has no member named 've'
main.c:326: error: 'vec_struct' has no member named 've'
main.c:349: error: 'vec_struct' has no member named 've'
main.c:384: error: expected ')' before numeric constant
main.c:384: error: stray '\' in program
main.c:385: error: stray '\' in program
main.c:386: error: stray '\' in program
main.c:391: error: expected ';' before '}' token
development?
Best
camilo
1630 Linden Dr.
___________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/i.spec.unmix-module-tp1884110p3372110.html
Stefan Sylla:
Same error here using grass-6.4.0svn.
Nikos
> Hi everyone
> subversion
> gcc
> development?
> Best
> camilo
On Sun, Aug 2, 2009 at 11:40 AM, Nikos
Alexandris<nikos.alexandris@felis.uni-freiburg.de> wrote:
Stefan Sylla:
The module needs yet to be ported to GRASS 6. Brad Douglas had worked
on it but never send his modifications. So I am afraid to say that someone
has to redo it.
Sorry for no better news,
