[GRASS-user] i.spectral and gnuplot
Hi
I'm trying to run i.spectral which of course requires gnuplot. I have gnuplot 4 installed (via fink) but i.spectral can't see it and asks for it to be installed. I made GRASS_GNUPLOT = /sw/bin but that didn't help. I'm running 6.1cvs on OSX 10.4.6. Any suggestions on how to make gnuplot visible to i.spectral would be much appreciated.
Stuart
There is a gratuitous check for whether gnuplot is in the path:
  #check if present
  if [ ! -x "`which gnuplot`" ] ; then
      echo "$PROG: gnuplot required, please install first" 2>&1
      exit 1
  fi
Remove that check from the i.spectral script. It actully uses
$GRASS_GNUPLOT to invoke it.
Glynn, Hamish
Thanks for looking into it. Since I'm hooked on Lorenzo's binaries I'll have to wait for his next update.
Stuart
  #check if present
      exit 1
  fi
grassuser mailing list
grassuser@grass.itc.it
Stuart,
I don't know about Mac's binaries, but i.spectral is actually a script and it is accessible using any editor. Check your script folder in your grass distribution and remove the gnuplot check strings which Glynn pointed out.
Francesco
At 15.43 26/06/2006, you wrote:
Glynn, Hamish
Stuart
        #check if present
            exit 1
        fi
Francesco
Ok -- that was straight forward (in the grand scheme of things) -- thanks. Now when I run i.spectral the following error is returned:
line 229: gnuplot: command not found
Is this a path problem on my part or something in the script? Is $GNUPLOT (from line 229) the same as GRASS_GNUPLOT (the environmental variable)? Wish I knew more about this! Thanks for any advice.
Stuart
On Jun 26, 2006, at 12:00 PM, francesco wrote:
Stuart,
Francesco
Glynn, Hamish
Stuart
        #check if present
            exit 1
        fi
any advice.
? I don't see a $GNUPLOT at or near line 229 in any version.
what does line 229 look like?
can you try using the latest CVS version?
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/scripts/i.spectral/i.spectral?rev=HEAD&content-type=text/plain
before you start the GRASS from a terminal shell, or placed in
.grass.bashrc have you set (assuming you use Bash and not Csh)
GRASS_GNUPLOT=/sw/wherever/gnuplot/is/gnuplot
export GRASS_GNUPLOT
Hamish
Can you access gnuplot from the unix bash by typing "gnuplot"? Probably not since it gives that line 229 error. I don't know about Mac, but either you have gnuplot installed as mac binary and not accessible by the unix shell, or you have a different name. Try installing gnuplot unix binaries.
Francesco Pirotti
At 04.18 27/06/2006, Stuart Edwards wrote:
Francesco
any advice.
Stuart
Stuart,
Francesco
Glynn, Hamish
Stuart
that
appreciated.
        #check if present
2>&1
            exit 1
        fi
Hamish, Francesco
After fearing for my sanity, I think I may have found the problem. The script in Lorenzo's binary distribution is not the same as the one that you pointed me to in spite of identical headers. Attached 'i.spectral' is from the distribution, 'i.spectral2' is the script at
  <http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/scripts/i.spectral/i.spectral?rev=HEAD&content-type=text/plain&gt;
The differences start at about line 51.
Tomorrow I'll have a crack at this again using the correct version! Gnuplot does open on command from the shell and GRASS_GNUPLOT = /sw/bin/gnuplot.
Regards
Stuart
(attachments)
i.spectral (1.5 KB)
i.spectral (4.96 KB)
i.spectral2 (1.5 KB)
i.spectral2 (5.6 KB)
i.spectral/i.spectral?rev=HEAD&content-type=text/plain>
you seem to have a version older than 11 May. here is the history:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/i.spectral/i.spectral
bin/gnuplot.
try
GRASS_GNUPLOT="/sw/bin/gnuplot -persist"
i.spectral
if /sw/bin/ is in your $PATH, then you don't need any of this.
does "which gnuplot" work from the terminal prompt?
perhaps add to ~/.grass.bashrc:
GRASS_ADDON_PATH=/sw/bin
export GRASS_ADDON_PATH
Hamish
What is the chance that i.spectral could use the new, expanded d.graph
instead of gnuplot for this? I haven't looked at the script, but this would
allow it to run without an external dependency.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 28 Jun 2006 00:52:13 -0400
To: Hamish <hamish_nospam@yahoo.com>
Cc: <grassuser@grass.itc.it>
Subject: Re: [GRASS-user] i.spectral and gnuplot
Hamish, Francesco
bin/gnuplot.
Regards
Stuart
any advice.
Hamish
Thanks to the efforts of Bejamin Ducke, I now have r.cva installed. However, it does not take a single point as the target, but requires a binary raster map containing either targets or viewpoints. I read the wiki and did some googling, but can't find out how to build such a map.
If QGIS can do this, I have it installed. I can generate a GPX file if that helps.
Hamish, Francesco
Back on this. Thanks for the tips. All were spot on. Now just a little (?) glitch in the execution. Script executes as it should if a 'group' is used. However if a list of rasters is used instead, the following errors occur:
GRASS 6.1.cvs (locationA):~ > i.spectral raster=AST6,AST7,AST8 -i
csh: if: Malformed file inquiry.
Click mouse button on desired location
              EAST: NORTH:
       748730.21875 3969381.53125 1
paste: data.dum: No such file or directory
gnuplot> set xtics ()
          "spectrum.gnuplot", line 1: invalid expression
This looks like it could be a Rev 1.6 issue since that's when it first became possible to use a group instead of the raster list.
Thanks again. Much learned!
Stuart
bin/gnuplot.
try
i.spectral
Hamish
Can you try changing the "#!/bin/sh" at the start to "#!/bin/sh -x"?
That should provide more information on exactly where it's failing.
ok -- here's the verbose version (looks like data.dum gets removed shortly before it is called for 'paste'):
GRASS 6.1.cvs (locationA):~ > i.spectral raster=AST6,AST7,AST8,AST9 -i
+ test /Applications/GRASS/grass61cvs.app/Contents/Resources/grass-6.1.cvs = ''
+ PARAM_NUM=2
+ '[' raster=AST6,AST7,AST8,AST9 '!=' @ARGS_PARSED@ ']'
+ exec g.parser /Applications/GRASS/grass61cvs.app/Contents/Resources/grass-6.1.cvs/scripts/i.spectral raster=AST6,AST7,AST8,AST9 -i
+ PARAM_NUM=1
+ '[' @ARGS_PARSED@ '!=' @ARGS_PARSED@ ']'
++ which /sw/bin/gnuplot -persist
+ '[' '!' -x /sw/bin/gnuplot ']'
++ which awk
+ '[' '!' -x /usr/bin/awk ']'
+ unset LC_ALL
+ export LC_NUMERIC=C
+ LC_NUMERIC=C
++ g.tempfile pid=1938
+ TMP1=/Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.0
+ TMP2=/Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.1
+ xlabels=
+ '[' 1 -eq 0 ']'
+ RASTERMAPS=
++ echo
++ sed 's+,+ +g'
+ news=
+ as=0
+ NUMBANDS=0
+ rm -f /Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.1
+ '[' 0 -eq 0 ']'
++ d.mon -L
++ grep -v 'not running'
++ wc -l
++ awk '{print $1}'
+ '[' 3 -eq 2 ']'
+ d.where -1
+ r.what input=
              EAST: NORTH:
  748435.03125 4969971.90625 1
+ cc=0
++ cat /Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.0
++ sed 's+\*+0+g'
++ sed 's+|+ +g'
+ TT=748435.03125 4969971.90625 1
++ wc -l
+ NUMCLICKS= 1
+ START=0
++ expr 0 + 1
+ START=1
++ echo '748435.03125|4969971.90625|1'
++ cut '-d|' -f1,2
++ tr '|' ' '
+ COORD[$START]=748435.03125 4969971.90625
++ sed 's+\*+0+g'
++ sed 's+|+ +g'
+ TOT=748435.03125 4969971.90625 1
+ cc=0
++ expr 0 + 1
+ cc=1
+ '[' 1 -gt 3 ']'
++ expr 1 + 1
+ cc=2
+ '[' 2 -gt 3 ']'
++ expr 2 + 1
+ cc=3
+ '[' 3 -gt 3 ']'
+ rm -f /Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.0
+ NUM=0
++ expr 0 / 1
+ NUM2=0
++ expr 0 + 1
+ NUM2=1
+ rm -f data.dum
+ i=0
+ '[' 0 '!=' 0 ']'
+ r=0
+ '[' 0 '!=' 1 ']'
++ expr 0 + 1
+ r=1
+ paste '-d ' data.dum /Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.1_1
+ rm -f /Users/stu/grassdata/locationA/stu/.tmp/SEsG4iBook.local/1938.1_1
+ '[' 1 '!=' 1 ']'
++ expr 0 + 1
+ xrange=1
+ echo 'set xtics ()'
+ echo 'set grid'
+ echo 'set title '\''Spectral signatures'\'''
+ echo 'set xrange [0:1]'
+ echo 'set noclabel'
+ echo 'set xlabel '\''Bands'\'''
+ echo 'set ylabel '\''DN Value'\'''
+ echo 'set data style lines'
+ rm -f data.dum
+ i=0
+ str=
+ '[' 0 '!=' 1 ']'
++ expr 0 + 1
+ i=1
+ '[' 1 -eq 1 ']'
+ '[' 0 -eq 0 ']'
+ str=plot 'data_1' title '1'
+ '[' 1 '!=' 1 ']'
+ str=plot 'data_1' title '1' with linespoints pt 779
+ echo plot ''\''data_1'\''' title ''\''1'\''' with linespoints pt 779
+ /sw/bin/gnuplot -persist spectrum.gnuplot
+ i=0
+ '[' 0 '!=' 1 ']'
++ expr 0 + 1
+ i=1
+ rm -f data_1
+ '[' 1 '!=' 1 ']'
+ rm -f spectrum.gnuplot
Stuart
_________________
Hello all,
It was a fat bug, my error, as expected ... I attach the fixed version of i.spectral (for the fast and furious), put it into your scripts folder... I'll have someone update the cvs...
Let me know if all goes well with this version, I just have little time for testing.
Francesco Pirotti
(attachments)
i.spectral (5.63 KB)
Hi
Getting close -- the new version contains the 'gratuitous' check for gnuplot identified by Glynn 6/24. With lines 52 -55 commented out though, it runs fine. Thanks for your help.
Stuart
______________
On Jul 12, 2006, at 10:48 AM, francesco wrote:
Hello all,
Francesco Pirotti
<i.spectral>
I've committed the part that fixes the variable name (GIS_OPT_RASTER).
map.
r.mapcalc "map=if(a, b, c)"
read: if (a) then "b", otherwise "c".
see the r.mapcalc help page.
Hamish
