[GRASS-user] i.superpixels.slic not working
Hello,
I’m trying to run the following:
i.superpixels.slic -n group=mod1@PERMANENT output=test num_pixels=5000 memory=10000
The output gives me the following:
(Mon Jun 12 10:17:40 2017)
Cache data in memory mode
Loading input…
WARNING: Initialized 5036 of 5070 seeds
Performing k mean segmentation…
And then I get a ‘GRASS 7 has stopped working’ box pop up.
I tried again with the default settings for the module:
i.superpixels.slic group=mod1@PERMANENT output=test
And got the same error.
I am using windows 10 professional and GRASS 7.3.svn (2017).
Has anyone else got this module working, or had the same problem on Windows?
Any help much appreciated.
Thanks
James
On 12/06/17 11:25, James Duffy wrote:
Hello,
I'm trying to run the following:
*i.superpixels.slic -n group=mod1@PERMANENT output=test num_pixels=5000
memory=10000
2017)
memory=10000
Loading input...
Performing k mean segmentation...
And then I get a 'GRASS 7 has stopped working' box pop up.
*i.superpixels.slic group=mod1@PERMANENT output=test
I haven't had any problems running it on Linux, and some colleagues have run it on Windows.
Just for our info: What are your region settings ?
Moritz
On 12 June 2017 at 10:36, Moritz Lennert <mlennert@club.worldonline.be>
Hello,
memory=10000
2017)
memory=10000
Loading input...
Windows?
run it on Windows.
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
north: 25183.22184529
south: 25157.71783908
west: 301463.66480893
east: 301494.2431551
nsres: 0.07775612
ewres: 0.0778075
rows: 328
cols: 393
cells: 128904
Just to add, I am running i.segment.uspo without problems using the same
imagery group and the same region.
Moritz
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
        Hello,
        num_pixels=5000
        memory=10000
        2017)
        num_pixels=5000
        memory=10000
        Loading input...
        on Windows?
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
nsres: 0.07775612
ewres: 0.0778075
rows: 328
cols: 393
cells: 128904
Yes, the region is actually very small, so no problem from there. It might be an issue with the memory handling. Could you try without setting the memory parameter, i.e. using its default value of 300 and tell us what happens ?
Moritz
On 12 June 2017 at 11:00, Moritz Lennert <mlennert@club.worldonline.be>
        Hello,
        num_pixels=5000
        memory=10000
        2017)
        num_pixels=5000
        memory=10000
        Loading input...
        on Windows?
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
nsres: 0.07775612
ewres: 0.0778075
rows: 328
cols: 393
cells: 128904
happens ?
*#default memory*
*i.superpixels.slic -n group=mod1@PERMANENT output=test *
Produced the same problem.
Moritz
        <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>
                Hello,
                num_pixels=5000
                memory=10000
                2017)
                num_pixels=5000
                memory=10000
                Loading input...
        problem
                on Windows?
        colleagues
        projection: 1 (UTM)
        zone: 43
        datum: wgs84
        ellipsoid: wgs84
        nsres: 0.07775612
        ewres: 0.0778075
        rows: 328
        cols: 393
        cells: 128904
        the same
*#default memory*
Can you reproduce using the NC demo data set ?
I.e.
g.region rast=ortho_2001_t792_1m
i.group ortho input=ortho_2001_t792_1m
i.superpixels.slic group=ortho out=slic_test
And tying with and without the '-n' flag and the memory parameter.
Moritz
                Hello,
                num_pixels=5000
                memory=10000
                2017)
                num_pixels=5000
                memory=10000
                Loading input...
        problem
                on Windows?
        colleagues
        projection: 1 (UTM)
        zone: 43
        datum: wgs84
        ellipsoid: wgs84
        nsres: 0.07775612
        ewres: 0.0778075
        rows: 328
        cols: 393
        cells: 128904
        the same
*#default memory*
I.e.
Ok, I think I found the culprit: https://trac.osgeo.org/grass/changeset/70961/.
@Markus: something in that modification creates a segfault in memory mode when running the above commands. When I try with the version just before, it works.
Moritz
On 12 June 2017 at 12:09, Moritz Lennert <mlennert@club.worldonline.be>
ine.be>
                Hello,
                num_pixels=5000
                memory=10000
                2017)
                num_pixels=5000
                memory=10000
                Loading input...
(2017).
        problem
                on Windows?
        colleagues
        projection: 1 (UTM)
        zone: 43
        datum: wgs84
        ellipsoid: wgs84
        nsres: 0.07775612
        ewres: 0.0778075
        rows: 328
        cols: 393
        cells: 128904
        the same
*#default memory*
I.e.
Running:
*g.region rast=ortho_2001_t792_1m i.group ortho input=ortho_2001_t792_1m
i.superpixels.slic group=ortho out=slic_test*
Worked for me.
*i.superpixels.slic -n group=ortho out=slic_test*
Also works.
*i.superpixels.slic group=ortho out=slic_test memory=10000 *
Crashed.
*i.superpixels.slic -n group=ortho out=slic_test memory=10000 *
Crashed.
Moritz
James
Le 12 juin 2017 15:25:36 GMT+02:00, James Duffy <james.philip.duffy@gmail.com> a écrit :
ine.be>
                Hello,
output=test
                num_pixels=5000
                memory=10000
                2017)
output=test
                num_pixels=5000
                memory=10000
                Loading input...
pop up.
module:
(2017).
same
        problem
                on Windows?
        colleagues
        projection: 1 (UTM)
        zone: 43
        datum: wgs84
        ellipsoid: wgs84
        nsres: 0.07775612
        ewres: 0.0778075
        rows: 328
        cols: 393
        cells: 128904
using
        the same
there. It
without
300
*#default memory*
I.e.
Running:
Worked for me.
Also works.
Crashed.
The issue arises when the module uses memory mode, i.e. when it reads the entire map into memory.
The issue is way above my pointer foo, so you'll have to wait for a fix and use only disk mode (by setting memory low enough) or download the previous version of the add-on from https://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.superpixels.slic?rev=70478&format=zip and install from the zip using g.extension ... url=.
Moritz
Crashed.
Moritz
James
On Mon, Jun 12, 2017 at 4:57 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
ine.be>
mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>> wrote:
Hello,
output=test
num_pixels=5000
memory=10000
2017)
output=test
num_pixels=5000
memory=10000
Loading input…
pop up.
module:
(2017).
same
problem
on Windows?
I haven’t had any problems running it on Linux, and some
colleagues
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
nsres: 0.07775612
ewres: 0.0778075
rows: 328
cols: 393
cells: 128904
using
the same
there. It
without
300
#default memory
I.e.
Running:
Worked for me.
Also works.
Crashed.
The issue is way above my pointer foo, so you’ll have to wait for a fix
Fixed in r71177. The windows add-on should be available by tomorrow.
Markus M
and use only disk mode (by setting memory low enough) or download the previous version of the add-on from https://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.superpixels.slic?rev=70478&format=zip and install from the zip using g.extension … url=.
Moritz
Crashed.
And tying with and without the ‘-n’ flag and the memory parameter.
Moritz
James
grass-user mailing list
grass-user@lists.osgeo.org
