[GRASS-user] Icelandic / international characters in databases and ps.map
After initially being put off by seeing complicated scripts, I've started to use psmap. I wanted to use the postscript fill patterns to create a geological map that would reproduce in black and white. It's really good - the commands are pretty easy and the results look clear and excellent.
Anyway. I have digitised some of the main peaks in the region, whose names contain Icelandic characters. Their names contain Icelandic characters. Using v.db.select, they appear to have stored correctly. When I use labels created from the vector, the characters appear as gaps with d.labels and as nonsense symbols using ps.map.
I read on the psmap g.manual page about character encoding, but don't know how it applies to the labels/database.
Can anyone help?
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
and excellent.
Can anyone help?
First, any text passed to ps.map must be in ISO-8859-1; other
encodings won't work (although if your PostScript interpreter has
suitable fonts, you can fix this by manually editing prolog.ps).
If you use FreeType fonts, d.* commands will work with any encoding
known to iconv (from the command line, you need to specify the
encoding via d.font; I don't recall how the GUI deals with this).
