Grassers:
I recall some time ago there was a way to “hack” grass (is this a more formal boot-time option now?) and have it ignore .gislock to run concurrent processes in the same mapset. I’m curious if this is still possible, and, if so, if it would be safe to do this with multiple r.mapcalc runs which use different input files and different output names? Thanks!
–j
Jonathan Greenberg wrote:
I recall some time ago there was a way to "hack" grass (is this a more
processes in the same mapset. I'm curious if this is still
possible,
The easiest way to get around the locking is to delete the .gislock
file.
This case should be safe.
