On 28/07/11 8:18 AM, grass-user-request@lists.osgeo.org wrote:
Message: 2
Date: Wed, 27 Jul 2011 08:24:45 -0700 (PDT)
Subject: Re: [GRASS-user] I'm in a hole and want to stop digging
[SOLVED]
To:grass-user@lists.osgeo.org
Message-ID:
<alpine.LNX.2.00.1107270822050.17199@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowedOn Wed, 27 Jul 2011, Richard Chirgwin wrote:
> My approach - I use MySQL but don't see why this would not work in pg - is to
> associate a schema to a mapset. So if I want PERMANENT and Project, over in
> MySQL I might run:
> create database Master
> create database ProjectRichard,
When I stepped back to look at the forest instead of the individual trees
I appreciate that I should have understood this; except I've not before
worked with an external database. Mea culpa!Since each mapset has it's own dbf/ directory for GRASS-internal vector
attributes, each mapset needs it's own external database, too.g.copy now works.
Thank you,
Rich
Rich,
My pleasure. I remember how much pain the database parameters caused me, when I was learning both Grass-GIS and MySQL at the same time!
Richard Chirgwin
