I would like to “segment” an image using a sort of Voronoi algorithm on a cost surface instead of distance between point.
Below you can see an image where the black pixels identity areas with high cost value. I would like to identify the “valley” between theses black areas.
In the second image I draft by hand an ideal solution for few high cost areas.
Which grass command can do this kind of delineation?
Giuseppe
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
Hi Giuseppe,
Maybe you can use r.watershed [0] to get the “basins”.
Best regards,
Pedro Venâncio
[0] https://grass.osgeo.org/grass72/manuals/r.watershed.html
(attachments)
2017-01-18 19:16 GMT+00:00 Giuseppe Amatulli <giuseppe.amatulli@gmail.com>:
Giuseppe
![Inline images 1]()
![Inline images 2]()
New Haven, 06511
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Pedro,
yes I had already tried, but i do not get really what I want. Moreover, the delineation of watersheds is based on a predefined threshold that can be quite arbitrary give really different results.
Best Giuseppe
(attachments)
On 18 January 2017 at 14:27, Pedro Venâncio <pedrongvenancio@gmail.com> wrote:
Hi Giuseppe,
Best regards,
Pedro Venâncio
Giuseppe
New Haven, 06511
New Haven, 06511
On Wed, Jan 18, 2017 at 8:16 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
You can use v.voronoi: first extract the pixels with high cost values with e.g.
r.mapcalc “high_cost = if(surface_map > threshold_value, 1, null())”
Then convert to vector areas with
r.to.vect input=high_cost output=high_cost type=area
Now create Voronoi triangles for areas with
v.voronoi input=high_cost output=high_cost_voronoi -a
HTH,
Markus M
Giuseppe
New Haven, 06511
Thanks Markus,
the problem with the v.voronoi is that the polygon borders will be calculate based on point distance and not on the cost surface.
Any other input?
Best
Giuseppe
On 19 January 2017 at 02:38, Markus Metz <markus.metz.giswork@gmail.com> wrote:
HTH,
Markus M
Giuseppe
New Haven, 06511
New Haven, 06511
Le Thu, 19 Jan 2017 11:08:13 -0500,
Giuseppe Amatulli <giuseppe.amatulli@gmail.com> a écrit :
Thanks Markus,
Any other input?
Seems to me that "voronoi" is not what you are looking for.
Maybe you could have a look at some of the topographic modules like
r.param.scale or the addon r.geomorphon to extract the valleys.
Or you could you r.watershed but output the streams and/or the
accumulation map to identify the valleys. Then some magic to reduce
these to lines (r.reclass + r.thin maybe).
Moritz
Best
Giuseppe
