Hello!
I am just starting to use GRASS.
I am trying to import a new Modis product about atmospheric aerosols.
I need to import hdf files, which have 13 bands (I am interested in band 1).
My problem is that each band has 3 dimensions (x-y-z : 1200x1200x4)
The z dimension corresponds to the orbit (Aqua or Terra, 2 daily overpass each). I would like to work with them separately.
When I try to open the file using r.in.gdal I get an error ‘The band does not exist’ (I guess the problem is the 3rd dimension…)
I also tried to import as 3d raster but did not get better results…
I attach an example hdf file: https://drive.google.com/open?id=17xtD5oij9etljTyey3Ka2d-IvfP8Gdpg
Looking forward for suggestions!
Thanks!
Lara
Hi Lara,
On Wed, Jun 19, 2019 at 7:06 PM Lara DC <dellaceca.lara@gmail.com> wrote:
Hello!
this hdf has 13 subdatasets, not 13 bands:
gdalinfo MCD19A2.A2018302.h19v05.006.2018311184807.hdf
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:Optical_Depth_047
SUBDATASET_1_DESC=[4x1200x1200] Optical_Depth_047 grid1km (16-bit integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:Optical_Depth_055
SUBDATASET_2_DESC=[4x1200x1200] Optical_Depth_055 grid1km (16-bit integer)
SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:AOD_Uncertainty
SUBDATASET_3_DESC=[4x1200x1200] AOD_Uncertainty grid1km (16-bit integer)
SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:FineModeFraction
SUBDATASET_4_DESC=[4x1200x1200] FineModeFraction grid1km (16-bit integer)
SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:Column_WV
SUBDATASET_5_DESC=[4x1200x1200] Column_WV grid1km (16-bit integer)
SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:AOD_QA
SUBDATASET_6_DESC=[4x1200x1200] AOD_QA grid1km (16-bit unsigned integer)
SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:AOD_MODEL
SUBDATASET_7_DESC=[4x1200x1200] AOD_MODEL grid1km (8-bit unsigned integer)
SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:Injection_Height
SUBDATASET_8_DESC=[4x1200x1200] Injection_Height grid1km (32-bit floating-point)
SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid5km:cosSZA
SUBDATASET_9_DESC=[4x240x240] cosSZA grid5km (16-bit integer)
SUBDATASET_10_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid5km:cosVZA
SUBDATASET_10_DESC=[4x240x240] cosVZA grid5km (16-bit integer)
SUBDATASET_11_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid5km:RelAZ
SUBDATASET_11_DESC=[4x240x240] RelAZ grid5km (16-bit integer)
SUBDATASET_12_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid5km:Scattering_Angle
SUBDATASET_12_DESC=[4x240x240] Scattering_Angle grid5km (16-bit integer)
SUBDATASET_13_NAME=HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid5km:Glint_Angle
SUBDATASET_13_DESC=[4x240x240] Glint_Angle grid5km (16-bit integer)
each subdataset has 4 bands (Aqua or Terra, 2 daily overpass each), e.g. for the first subdataset
gdalinfo HDF4_EOS:EOS_GRID:“MCD19A2.A2018302.h19v05.006.2018311184807.hdf”:grid1km:Optical_Depth_047
Band 1 Block=1200x833 Type=Int16, ColorInterp=Gray
Description = AOD at 0.47 micron
NoData Value=-28672
Offset: 0, Scale:0.001
Band 2 Block=1200x833 Type=Int16, ColorInterp=Gray
NoData Value=-28672
Band 3 Block=1200x833 Type=Int16, ColorInterp=Gray
NoData Value=-28672
Band 4 Block=1200x833 Type=Int16, ColorInterp=Gray
NoData Value=-28672
for r.in.gdal, you need to use the subdataset as input
HTH,
Markus M
Hi Lara,
On Wed, Jun 19, 2019 at 7:05 PM Lara DC <dellaceca.lara@gmail.com> wrote:
Hello!
In addition to Markus Metz's detailed answer, HDF is also mentioned in
the manual page:
https://grass.osgeo.org/grass76/manuals/r.in.gdal.html#hdf
Please suggest improvements to the manual as needed!
markusN
