Hi!
I want to import a set (20) of ESRI ASCII raster files in a catalog, and merge them to a single GRASS raster dataset.
How do I do that? (Yes I can import each file, and then merge (r.patch), but..)
Regards larsf
Hi!
Regards larsf
Thanks Daniel.
But no, I was not able to make your suggestion work; it complains that it dos not know the command ‘For’…
Regards larsf
Den 01. april 2012 16:01, skrev Daniel Victoria:
I believe there is a batch import function in the gui ( I’m not in front of my computer now). If not, you can write a for loop in the command line to import all files.
In Linux shell it’s something like
For i in *.arc
Do r.in.arc $i
DoneDaniel
On Apr 1, 2012 10:13 AM, “Lars Forseth” <lars.forseth@ntebb.no> wrote:
Hi!
I want to import a set (20) of ESRI ASCII raster files in a catalog, and merge them to a single GRASS raster dataset.How do I do that? (Yes I can import each file, and then merge (r.patch), but…)
Regards larsf
grass-user mailing list
grass-user@lists.osgeo.org
Lars Forseth wrote:
Thanks Daniel.
dos not know the command 'For'...
In Linux shell and msys this must be lowercase, i.e.
for i in *.arc
do r.in.arc $i <output name here>
done
or
for i in *.arc
do r.in.arc in=$i out=`basename $i .arc`
done
followed by something like
raster_list=`g.mlist type=rast pat=<insert search pattern here> sep=comma`
g.region -p rast=$raster_list
r.patch in=$raster_list out=<output name here>
HTH,
Markus M
Regards larsf
I believe there is a batch import function in the gui ( I'm not in front of
import all files.
In Linux shell it's something like
For i in *.arc
Do r.in.arc $i <output name here>
DoneDaniel
On Apr 1, 2012 10:13 AM, "Lars Forseth" <lars.forseth@ntebb.no> wrote:
Hi!
but..)Regards larsf
http://lists.osgeo.org/mailman/listinfo/grass-user_______________________________________________
Hi!
In help for r.patch I found this:
MAPS=`g.mlist type=rast sep=, pat="map_*"`
g.region rast=$MAPS
r.patch in=$MAPS out=mosaic
That worked for me now.
I importet all files in the catalog by defining import source in the gui for r.in.gdal as directory; choosing the right directory; and it then imported all the files, giving them a "prefix" of x2; or some such.
I shall try Markus suggestions next!
regards; and thanks!
larsf
Den 01. april 2012 18:42, skrev Markus Metz:
Lars Forseth wrote:
Thanks Daniel.
dos not know the command 'For'...In Linux shell and msys this must be lowercase, i.e.
for i in *.arc
do r.in.arc $i<output name here>
doneor
for i in *.arc
donefollowed by something like
r.patch in=$raster_list out=<output name here>HTH,
Markus M
Regards larsf
import all files.
For i in *.arc
Do r.in.arc $i<output name here>
DoneDaniel
On Apr 1, 2012 10:13 AM, "Lars Forseth"<lars.forseth@ntebb.no> wrote:
Hi!
but..)Regards larsf
On Sun, Apr 1, 2012 at 2:43 PM, Lars Forseth <lars.forseth@ntebb.no> wrote:
Hi!
but..)
Just FYI, there is also graphical bulk import:
http://grass.osgeo.org/wiki/Importing_data#Importing_multiple_raster_.28e.g..2C_GeoTIFF.29_files
--> screenshots
cheers
