I am getting an error when importing a .xyz file with the coordinates
of a scene. The only reason i am looking at is the fact that the z value
is negative, and after the field separator (,).
Also, after importing how should i build a surface (TIN) and create a
shaded surface?
Here is the error:
Error reading ascii file:
1499.4708,4314.6574,-1.5260
value is negative, and after the field separator (,).
Here is the error:
what are the v.in.ascii command line options you are using?
what version of GRASS?
fs=, ?
why format=standard not format=point? If using format=standard you need
to use the special format described in the v.in.ascii help page.
Look at the v.surf.* modules. (technically a raster surface not a TIN)
One can create a raster surface which will look the same as the
rasterised TIN with r.surf.nnbathy from GRASS WIKI raster AddOns site
[1]. Use alg=l for that. See the manual provided in the zip file for
details.
You may want to build a TIN for other reasons, but (unlike ArcGIS) you don¹t
need it in GRASS for displaying shaded relief maps and 2.5 (or even 3D)
maps.
There is a shaded relief module (r.shaded.relief) that runs directly from a
raster map. You can get 2.5-4D displays in NVIZ directly from rasters and
volumes (and 3D vectors too) without making a TIN.
Michael
shaded surface?
Here is the error:
Ricardo
Arizona State University
