[GRASS-user] Import CH1903 Referenced Geodata
Hi Adrian,
if you open a e00-file from the same web-site in an texteditor, you can find the following projection info:
  Projection OBLIQUE
  Units meters
Spheroid BESSEL
Datum user_defined 674. 14. 405.
Parameters
2 /* Projection type < 1 | 2 >
1 /* Scale factor at the projection's center
7 26 22.5 /* Longitude of the projection's center (DMS)
46 57 08.66 /* Latitude of the projection's center (DMS)
90.000000 /* Azimuth at the projection's center
-9419820.5907 /* False easting (meters)
  200000.0000 /* False northing (meters)
Hope this helps to find and define the right projection to import the shapefile.
Best regards
helli
Hello There,
I'm trying to import the sample shapefile from
http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/downloads/landscape/vector25.html
(ArcView Shapefile) into GRASS 6.3.
I guess the Coordinate Reference System for the data is CH1903+ /LV95,
EPSG code 2056.
_________________________________________________________________________
Sensationsangebot nur bis 30.11: WEB.DE FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.web.de/?ac=OM.AD.AD008K13805B7069a
