[GRASS-user] import DWG files ?
is it still possible to import dwg files in grass6.2.3
I remember that I did that with grass6.0.1 and the OpenAlliance library.
best regards,
Grégoire
Hi Grégoire,
it is still possible to compile grass with the the option
--with-opendwg, then specify where is located your ad2.h and other files
needed by v.in.dwg.
You have to subscribe to Open Design Alliance (ODA) to obtain the
opendwg toolkit ; AFAIR you have to pay $250 to register (formerly
free...).
Yours,
Vincent
Le mercredi 01 avril 2009 à 17:50 +0200, Grégoire Pigeon a écrit :
best regards,
Grégoire
grass-user mailing list
grass-user@lists.osgeo.org
2009/4/1 Grégoire Pigeon <gregoire.pigeon@meteo.fr>:
should be possible (you need to compile v.in.dwg). Anyway I would
recommend you to use documented formats instead of DWG. Also consider
updating to GRASS 6.4.0.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Another option is to get the free ODA (no membership necessary) 'EveryDWG' converter. It will nicely convert all dwgs or binary dxfs to ASCI dxf and then you can use v.in.dxf. Unfortunately it only runs on Windows.
Stu
On Apr 1, 2009, at 12:32 PM, Vincent Bain wrote:
Hi Grégoire,
needed by v.in.dwg.
free...).
Yours,
Vincent
best regards,
Grégoire
