I cannot find the answer to my specific problem through the existing threads, nor can I properly search the GRASS list archives (that's another issue, but when I click one of my search results, a DIFFERENT message shows up unrelated to the link I clicked).
Here is my problem. I have a few e00 rasters from ArcGIS. When I view them in ArcMap, everything is fine. When I import using GRASS, with avcimport and e00conv installed, the maps display properly (I can see the different categories, etc.). However, the z value is simply a *. So when I query the file in a monitor, I get UTM-X | UTM-Y | *
Clearly, this is not the intended outcome! I do not get errors during the import, and I have tried exporting the e00 in different formats from ArcCatalog, and wondered if I should be converting my files to a different format instead of dealing with ESRI e00?
The other thing I attempted is to convert the e00 to an ASCII file in ArcInfo, then to import the ESRI ASCII in GRASS. Again, same result as above.
Am I having projection issues? Do I need to first import the e00/ASCII to a mapset with the same projection settings as the original e00, then re-project, or is this unrelated? I think I had tried that already, with the same result as above, but am willing to try again if need be.
What other conversion options may work from within Arc?
The * value is for NULL data. Is there any region clipping occurring or MASK applied? Someone else may be able to intelligently speak to the issue of data displaying ok (colors/categories) but having a NULL data value. That I cant understand. Is your location setup properly, with broad enough extents to encompass the raster?
I had some issues with the e00’s. I cant recall specicifally. for best raster interoperability, I found the in Arc, you can export to raster to ASCII (.txt file by default) or export from GRASS as ASCII (*.txt), and use the conversion toolbox “from raster/to raster” to import export.
as above.
I’d stick with the ASCII grid file for interchanging.
if need be.
Is all your data in the same projection? What projection is your GRID/raster in, and what projection is your other data in?
for rasters, I found the ASCII GRID format to be the best for importing/exporting data.
