[GRASS-user] import more kml from directory
Ciao Grass users.
Probably my question is trivial, but I can not fix.
1) I want to import many files. kml (all in the same folder) and then I
would like a merge(with v.patch).
I tried to import v.in.ogr all together .... maybe I'm wrong.
2) Maybe I can do a merge of all files with ogr2ogr?
Thanks for any advice
View this message in context: http://osgeo-org.1803224.n2.nabble.com/import-more-kml-from-directory-tp6050317p6050317.html
folder) and then I
wrong.
I'll let others talk about new developments in v.in.ogr and
the GUI which may help with that.
but from the unix command line (or Msys command line in MS
Windows) you could do like:
- make sure filenames are SQL compliant (no dots except the.kml,
start with a letter, ..)
- run a little loop on the unix command line:
for file in *.kml ; do
   v.in.ogr dsn="$file" output=`basename $file .kml`
done
then to patch them all together:
v.patch out=merged_kml in=`g.mlist vect sep=, pattern="*"`
(refine pattern= to just your input maps as needed, or leave
that out to list all vector maps)
perhaps
Hamish
Ciao Hamish and thanks.
It works.... ok :slight_smile:
But I have also tried with my small script (attached) that does not work and
I did not understand why. Maybe, if you want, you can watch it.
Thank you very much.
http://osgeo-org.1803224.n2.nabble.com/file/n6052924/v.import_kml.sh
v.import_kml.sh
View this message in context: http://osgeo-org.1803224.n2.nabble.com/import-more-kml-from-directory-tp6050317p6052924.html
v.import_km
I think I can see two problems with the script:
First, the dsn= parameter should be the full kml file name, i.e. ${i} as you have set up the loop, and not the just the basename ${cartella}.
Second, I think that the layer= option is not necessary. And you surely should not set it to the output name $nome. The layer= option takes a number (i.e. the number of the layer).
HTH
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
and
v.import_km
For pretty much all other vector modules, the layer option takes a
number and refers to a GRASS vector layer number. For v.in.ogr, the
layer option is the name, not the number, of an OGR layer. OGR layer
names available in a given dsn are printed with v.in.ogr -l. BTW, one
single kml file can contain several layers.
Markus M
Ciao.
Thanks.
Now, although "crude", it works. However, I put "exit" (or exit 0 exit 1)
at the end but the script does not finish properly.
What do you say?
Thanks
http://osgeo-org.1803224.n2.nabble.com/file/n6057767/v.import_kml.sh
v.import_kml.sh
View this message in context: http://osgeo-org.1803224.n2.nabble.com/import-more-kml-from-directory-tp6050317p6057767.html
and
v.import_km
Ooops, sorry for misleading, and thanks, Markus, for catching that.
(BTW, will the term "layer" be changing its meaning in GRASS 7?? There was much discussion on this some time ago, and alternative names were suggested for the database connection concept that "layer" was meant to refer to)
Markus M
This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
