[GRASS-user] Import question
I have a series of points in an ascii files that represent points along a line. I would like to import them as a line, or import and convert to a line.
I see that 6.5 has v.in.lines, but I am using 6.4. Is there any other way to do that conversion?
The data is 3D x,y,z points. I can just import them using v.in.ascii, but then they are points, with no lines. Is there another way to either import, directly, or convert?
--Adam
If it's only one line, then the simplest might be to re-write the ASCII file formated in the GRASS "standard" format, as a line. You'll need to add the header lines, something like:
VERTI:
L n 1
X_coord Y_coord
1 1
Where 'n' is the number of points.
Then run v.in.ascii ... format=standard and it should result in a line vector.
--Adam
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
VERTI:
L n 1
X_coord Y_coord
1 1
Thanks. It is actually one line, at the moment, so I did that, and it worked fine. But I will have others. so was hoping for a generic solution. I wrote a shell script that transforms my particular data into "standard" and it seems to be working fine.
Again, thanks for the response.
--Adam
since it seems to be open season on backporting stuff, if there
is widespread demand, and no objections, I'd consider backporting
it for 6.4.1. but really it is just a wrapper script around
v.in.mapgen. the most valuable thing about it is the easy to
understand module name.
Hamish
is widespread demand, and no objections, I’d consider backporting
Thanks. Once I heard that it is just a script, I downloaded it myself. So, don’t backport it on my account. But, I do appreciate the thought.
–Adam
