WARNING: G_set_window(): Illegal latitude for North
so I used the -l option. The file appears to have imported
GRASS 6.4.3 (globe_30s):~ > r.in.gdal -l in=~/projects/global_aridity/AI_annual/ai_yr/w001001.adf out=ai
WARNING: Map bounds have been constrained to geographic coordinates. You
will almost certainly want to check map bounds and resolution with
r.info and reset them with r.region before going any further.
Projection of input dataset and current location appear to match
100%
r.in.gdal complete. Raster map created.
I am trying to check the layer with r.info and I see that the resolution looks odd (N looks correct, should be 30 second, but E looks weird):
GRASS 6.4.3 (globe_30s):~ > r.info ai
| Layer: ai Date: Tue Sep 24 11:06:02 2013 |
| Mapset: global_aridity_pet Login of Creator: kirkw |
| DataBase: /Volumes/disk1/home1/kirkw/grassdata |
| Title: ( ai ) |
Originally I was getting the warning:
As the message says, you need to fix the raster extents and resolution
with r.region
