[ Sorry for bombing you with questions - I am close to complete my work
and need to clarify all details in my document. And BTW, GRASS plays
bouzouki!!! (something like the greek version of "GRASS Rocks!") ]
Could it be a cell center / corner issue? Normally header information
gives cell corners...
Daniel
On Tue, Mar 18, 2008 at 10:07 AM, Nikos Alexandris
If gdalinfo can read it, why not use r.in.gdal instead of r.in.bin?
It's less work.
(a) why isn't the command logged in the maps history?
r.in.bin and r.in.ascii now updated in 6.3svn to write out command
history. (This has had to be done manually for all modules which create
raster maps. We have now done this for most of the common modules and so
it is encouraging for folks to find it strange when it is missing)
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
Nikos:
> You are the Man! Correct!
> 1. gdalinfo /home/nik/grassdb/tmp/glc2000/Binary/GLC_EU_V2.bil -noct
> Driver: EHdr/ESRI .hdr Labelled
> Files: /home/nik/grassdb/tmp/glc2000/Binary/GLC_EU_V2.bil
> /home/nik/grassdb/tmp/glc2000/Binary/GLC_EU_V2.hdr
> /home/nik/grassdb/tmp/glc2000/Binary/GLC_EU_V2.stx
> /home/nik/grassdb/tmp/glc2000/Binary/GLC_EU_V2.clr
> Size is 8064, 4256
It's less work.
Correct! But, for the sake of demonstration, I will keep both ways in my
document.
Hamish,
I am sorry but my english has its (greek) limits. You write "it is
encouraging ... to find it strange" but I don't understand what this
means. Can you please explain? Maybe it's nothing important or so
easy... but I don't get it right now (?)
