Dear all,
I have two mapsets, one on my c:\DATA and other on my H:\HDEXT external disk.
The first (my target database) are setted as LatLong/WGS84 projection.
The 2nd (my source database) are setted as UTM/SouthAmericaDatum1969 (zone 24).
I tryed this command to import a map from UTM to WGS:
(I run this command from target mapset)
r.proj --v input=mapIN output=mapOUT location=newLocationX mapset=PERMANENT dbase=H:/HEXT/database
r.proj appears to understand the information from both (input and output) side (see message I get):
Input Projection Parameters: +proj=utm +south +no_defs +zone=24
+a=6378160 +rf=298.25 +towgs84=-57,1,-41,0,0,0,0
But after that r.proj crash under Vista/Windows 64b:
“r.proj.exe has stopped to working - a problem caused the rogram to stop working correctly…”.
Any help are welcome.
milton
brazil=toronto
