[GRASS-user] Importing a Scanned Map
Hello,
I am trying to import a raster map using r.in.gdal. The map was previously georeferenced in Q-GIS. When I run r.in.gdal, I receive the message that the projection of dataset does not appear to match current location.
I used the location parameter to create a new location for the scanned map. When I attempted to re-project the map from my new location into my intended GRASS location, I received the following error:
Unable to get projection info of input map.
Looking at the projection information, the projection for the scanned map and for my GRASS location match, with the exception of the cellhd.proj parameter. The scanned map’s cellhd.proj = 0 (unreferenced/unknown).
I’m not familiar with the function of the cellhd.proj. Could someone shed some light on how I might be able to resolve the issue?
Dave
David Kindem
Grand Haven, MI
What format is the map in?
On Sun, Sep 5, 2010 at 10:50 AM, David Kindem <dkindem@gmail.com> wrote:
Hello,
Dave
David Kindem
Grand Haven, MI
grass-user mailing list
grass-user@lists.osgeo.org
The file is a .tif file with two associated files, a .wld and a tif.aux.xml.
Dave
David Kindem
Hello,
Dave
David Kindem
Grand Haven, MI
I believe the wld is a world file, all it has is the coordinate but not the projection infos (not sure about the xml file though). I would suggest you create a dummy GRASS mapset with the projection your tif file was georeferenced at, then use r.proj to import it in your intended location. let me know if I missed the point you were trying to make.
Dave
David Kindem
Hello,
Dave
David Kindem
Grand Haven, MI
You don't need to create different location if that GeoTIFF has same
coordinate system as Your current GRASS location. Just use r.in.gdal
override flag to import it without checking coordinate system match.
Remember - source and destination MUST have identical coordinate
systems (except for extent).
Maris.
2010/9/5, kapo coulibaly <kmcoulib@gmail.com>:
tif.aux.xml.
Dave
David Kindem
Hello,
location.
parameter. The scanned map's cellhd.proj = 0 (unreferenced/unknown).
I'm not familiar with the function of the cellhd.proj. Could someone
shed
Dave
David Kindem
Grand Haven, MI
Thanks Maris, that did the trick.
Dave
David Kindem
On Sep 5, 2010, at 1:48 PM, Maris Nartiss wrote:
You don’t need to create different location if that GeoTIFF has same
Maris.
tif.aux.xml.
Dave
David Kindem
Hello,
location.
shed
Dave
David Kindem
Grand Haven, MI
