-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 27/06/12 18:36, Daniel Lee wrote:
Hi Rich,
Thanks for the tip. Unfortunately, r.in.ascii is made for files with another type of header.
Nonetheless, I tried it and here's the output:
r.in.ascii input=/home/lee/co2/daten/gcm_results/prec_1.asc output=test "north" field missing
from header "south" field missing from header "east" field missing from header "west" field
missing from header "rows" field missing from header "cols" field missing from header Illegal
row value ERROR: Can't get cell header
I just checked - I have files with the extension .asc which start as follow:
ncols 790
nrows 210
xllcorner 574000
yllcorner 6242000
cellsize 100.000000
NODATA_value -9999
- -9999 -9999 -9999 -9999 ...
and I read them in via r.in.arc and it works ...
As I said, try the gdal, maybe more robust?
Rainer
Those values aren't in the header though and the requirements of r.in.arc match the header
QGIS manages to open it, but I don't know how to script it and it's quite a large number of
datasets.
Any other ideas? Does anyone have experience with opening and exporting rasters in QGIS from a
script? That would make things a bit easier, otherwise it takes a good 5 minutes or so to open
each file.
Thanks! Daniel
B.Sc. Daniel Lee Geschäftsführung für Forschung und Entwicklung ISIS - International Solar
Information Solutions GbR Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3 35037 Marburg Festnetz: +49 6421 379 6256 Mobil: +49 176 6127 7269 E-Mail:
Lee@isi-solutions.org <mailto:Lee@isi-solutions.org> Web: http://www.isi-solutions.org
<http://www.isi-solutions.org/>
2012/6/27 Rich Shepard <rshepard@appl-ecosys.com <mailto:rshepard@appl-ecosys.com>>
On Wed, 27 Jun 2012, Daniel Lee wrote:
I'm having a lot of trouble importing some ASCII data into GRASS. It seems
like a perfect case for r.in.arc, but r.in.arc isn't working. Here's some info:
Daniel,
From the 6.5 manual r. index:
r.in.arc Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map
layer. r.in.ascii Converts ASCII raster file to binary raster map layer.
Try r.in.ascii.
Rich
-- Richard B. Shepard, Ph.D. | Integrity - Credibility - Innovation Applied
Ecosystem Services, Inc. | Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com> Voice: 503-667-4517 <tel:503-667-4517> Fax: 503-667-8863
<tel:503-667-8863>
_________________________________________________ grass-user mailing list
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/grass-user
<http://lists.osgeo.org/mailman/listinfo/grass-user>
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk/rSg4ACgkQoYgNqgF2egqDVwCcDcPjxlgBCeKosEBqMthvh8J4
/00An02EcYMFwxw+z6IvS+p48xros2Yy
=GHGx
-----END PGP SIGNATURE-----
