I was playing with big vector data and trying import it into GRASS
native format. I used 'buildings' layer from OSM provided in Esri
Shapefile for region of the Czech Republic [1].
This layer has almost 3.5 milions of polygons.
$ ogrinfo buildings.shp -al | grep 'Count:'
Feature Count: 3464029
I used PC with 16 CPUs (Intel Xeon @ 2.53GHz) a 48GB RAM with 64bit
Debian stable. GRASS compiled with large-file support.
1) $ v.in.ogr dsn=buildings.shp
-> after 30min failed with "Unexpected error. Aborted", memory usage peak 4.1GB
2) $ v.in.ogr -c dsn=buildings.shp
-> 20min with 3.0GB memory peak
The result was not topologically clean, but import procedure finished.
3) $ GRASS_VECTOR_LOWMEM=1 v.in.ogr dsn=buildings.shp
-> after 110min failed with "ERROR: G_calloc: unable to allocate 101 *
4 bytes of memory at allocation.c:81" (when Finding centroids for OGR
layer <buildings>...), memory peak 3.6GB
4) shp->postgis + v.external (simple features)
$ shp2pgsql -I -D -S buildings.shp | psql pgis_db
in 2min!
$ v.external dsn=PG:dbname=pgis_db layer=buildings
-> after 9min failed with "G_realloc: unable to allocate 40800000
bytes of memory at cindex.c:113"
GRASS_VECTOR_LOWMEM=1 v.external dsn=PG:dbname=pgis_db layer=buildings
-> it took 17min with memory peak 2.2GB, link was created!
I tried to render such data
$ d.mon cairo output=/tmp/buildings.png
$ g.region vect=buildings
$ d.vect buildings
but failed in 30sec with
ERROR: G_realloc: unable to allocate 48000 bytes of memory at list.c:46
Any comments, suggesting are highly welcomed...
Thanks, Martin
[1] http://download.geofabrik.de/europe/czech-republic-latest.shp.zip
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
