It seem that you have a tiff instead of a geo-tiff fil.
If you have a tiff file you'll need to import it on an XY location and
then geo-reference it. You can find a clear explanation of the process on
M. Neteler, H. Mitasova: “Open Source GIS: A GRASS GIS Approach”.(3ª
edic.) 2008. Springer.
I have a scheme of the process (in Spanish) on
http://lsi.ugr.es/~jctorres/gis/tema4.html/, slides 5 to 7.
Juan Carlos Torres
Joe Bayles escribió:
I've tried both a predefined location and an undefined XY, either way
the options are throwing me off. When I try to set the extents or
resolution, the functionality won't work, for example, when setting up
a new location or extent or mapset, the N S E W boundaries are set to
1, and I can only change North and South.
Joe Bayles
baylesjm@jmu.edu <mailto:baylesjm@jmu.edu>
joseph.bayles@us.army.mil <mailto:joseph.bayles@us.army.mil>
(703) 677-2539
AIM: joebayles
On Mon, Apr 27, 2009 at 12:02, Juan Carlos Torres Cantero
<jctorres@ugr.es <mailto:jctorres@ugr.es>> wrote:
Joe
You can import it both ways. Using a predefined location or asking
r.in.gdal to create a new one.
Anyway, you'll get three RASTER maps corresponding to the three colors
chanels (tiff files are raster). If you want a color copy of the input
map youl'll
need to use r.composite to mix them. And if you need a vector map
you'll
need to extract features from the raster map thin them and convert to
vector
using r.to.vect.
Juan Carlos Torres
> Hello, I'm trying to figure out how to use GRASS (brand new
user) and
> I am having a hard time switching over. I have a TIFF file I want to
> import and from that create a vector map using georeferencing. Every
> time I think I've imported it correctly, nothing shows up. I've done
> this both before and after creating a new map set, though I
don't know
> how effective that was. I have been using r.in.gdal, but I don't
know
> if this is what I want. I know this is a bit of a general question,
> but I'm a bit lost. Thanks.
> Joe
> grass-user mailing list
> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
