[GRASS-user] Importing DEM - r.in.srtm: unzip required, please install first
Hi all, first time posting for me.
Running GRASS 6.2 through Cygwin on Windows XP, I'm trying to import a DEM saved in SRTM-format (.hgt) which I got from http://www.viewfinderpanoramas.org/dem3.html
Both in the command-line and GUI versions I get this rather curious error:
I have no idea what this means, and since I'm working with data at 66deg north, this is the only source I've found that give me a working DEM. I've earlier used them through PCI, so I know they work. Unfortunately I've no longer got access to PCI.
Any help would be most welcome.
It means that r.in.srtm cannot find the unzip program to decompress the file.
2007/5/1, Jarle Pedersen <mybigb@gmail.com>:
grassuser mailing list
grassuser@grass.itc.it
Hernán De Angelis
Linux user # 397217
> error: r.in.srtm: unzip required, please install first
the file.
I have just added "unzip" to list of suggested Cygwin packages on the
download page.
r.in.srtm expects the .hgt file to be zipped (WinZip, etc). It should be
named like "S46E166.hgt.zip".
Hamish
>> > importa DEM saved in SRTM-format (.hgt) which I got from
>> >curious error: r.in.srtm: unzip required, please install first
>> the file.
Hamish:
> the download page.
> should be named like "S46E166.hgt.zip".
Jarle:
I installed the unzip-package via Cygwin, and now I get the following
error which seems to be related to your last comment:
"/usr/local/grass-6.2.1/scripts/r.in.srtm: line 135: file: command not
found
/home/Anonymized/Helgeland/dem/N65E012.hgt.zip is no zip file."
"file" is another common UNIX tool for testing file types, which
apparently cygwin doesn't include by default. Install the cygwin "file"
package. You'll also need "grep" -- is that package already installed?
How about "install"? (try: "which grep" and "which install")
Problem is I did zip the file, but did so via Winzip. Might this have
something to do with it?
No, that should be fine; it's the missing "file" program that makes the
file type test fail.
I have just updated r.in.srtm in 6.3cvs to work even if the file is
already unzipped. The new version is currently not backwards compatible
with GRASS 6.2 due to grass bug #381.
Thanks again for any help, and terribly sorry to occupy this mail-list
with such trivial questions.
They are useful. By pointing out deficiencies in the documentation, we
can know to fix them, then the next person doesn't have the same
troubles, and thus the software gets a little bit better.
Hamish
