[GRASS-user] importing .dgn files in grass
hi all
I have been able to import a dgn file into grass using the v.in.ogr but I have all the point, line and poly
features in the same layer. Next When i use v.what then I get a attribute listing which I can’t quite understand
Anyone who can help me out with - how to seperate the point , lines and polys into three different layers. Also
if possible there could be different things represented as lines - roads and rivers both are line features. So how to extract these from the .dgn file into two different layers. I am attaching the output of v.what command for ease of anyone who wishes to help me out.
Output of Grass v.what command :-
East: -21786.9555969
North: -23164.1739966
Map: nkd
Mapset: PERMANENT
Point
Layer: 1
Category: 9362
driver: dbf
database: /ramdisk/grass/locations/43p/PERMANENT/dbf/
table: nkd
key column: cat
cat : 9362
Type : 17
Level : 3
GraphicGro : 0
ColorIndex : 0
Weight : 1
Style : 0
EntityNum :
MSLink :
Text : Paswal
When I try to see the layers in the .dgn file using the option list available layers in the dataset and exit from v.in.ogr
I get the output
Data source contains 1 layers:
elements
But I think the data source contains more than one layer - atleast one line, one point and one poly for sure. What is the meaning of the above output…
Thanks in advance.
Nishith
--- nishith datta <nkdiitd2002@gmail.com> escribió:
hi all
listing which I can't quite understand
Map: nkd
Mapset: PERMANENT
Point
Layer: 1
Category: 9362
driver: dbf
database:
table: nkd
key column: cat
cat : 9362
Type : 17
Level : 3
GraphicGro : 0
ColorIndex : 0
Weight : 1
Style : 0
EntityNum :
MSLink :
Text : Paswal
the option list
v.in.ogr
I get the output
elements
of the above
output.....
Thanks in advance.
Nishith
GRASS Layer, is not the same of dgn's Layer(Level)
Make a external database conection:
v.external dsn=yourmap.dgn output=yourmap
open yourmap in a monitor
You can test every entity in the dgn with v.what
Make attention on the Level value, and others fields
values of the entities you want to include in a vector
GRASS file.
Import just this entities with the the option
"where=":
v.in.ogr -z -o dsn=yourmap.dgn output=yourmapX
where=Level=X min_area=0.0001 snap=-1
And so on for each map
Juan M. Garijo
______________________________________________
LLama Gratis a cualquier PC del Mundo.
Llamadas a fijos y móviles desde 1 céntimo por minuto.
http://es.voice.yahoo.com
