Thanks for your help.
I expectged it to be problematic. What I will do: install grass 5.4.2 as
well and import to a format which can be read from both.
Rainer
M S wrote:
I hope someone else has a better solution that doesnt involve using arcCatalog. If you dont have ArcCatalog, someone else will have to provide a solution for you.
the e00's pre-date arcMap, and apparently from what I have experienced, even though the .e00 are ASCII interchange files, they are not the same as an "ESRI ASCII Raster file" produced by ArcCatalog within ArcMap. (arc/info workstation .e00 ascii file <> arcMap .txt ascii file)
I cant see how to import a raster .e00 file directly. I would be grateful to hear from someone how to do this. I checked the GDAL page also, but could not find the answer.
what will work is this:
Use ArcCatalog (or arc/info workstation) to import the .e00 file to an ESRI GRID.
Use ArcToolBox, under "Conversion Tools", then "From Raster", then "Raster to ASCII" dialog.
Input the raster, Input the output ASCII raster file in the dialog box. This will output a <outfile>.txt file.
this ASCII text file can be imported using the r.in.arc (File-->Import-->Raster Map-->ESRI Arc/Info ASCII grid)
Mark
On 8/15/07, *Rainer M. Krug* <Rainer@krugs.de <mailto:Rainer@krugs.de>> wrote:
M S wrote:
> Looks like it is a raster/GRID, and not vector?
I might agree with that. So I should use m.in.e00 - but as far as I have
seen, it is not available for grass 6.2. Is there another way of
importing them
<mailto:Rainer@krugs.de> <mailto:Rainer@krugs.de
<mailto:Rainer@krugs.de>>>
> wrote:
> Hi
> System:
> SuSE Linux 10.2
> grass 6.2
> e00compr-1.0.0
> avce00-2.0.0
> I want to import an .e00 file, but I get the following error
message:
> > v.in.e00 -v file=aveanrfl.e00 type=area vect=test
> An error may appear next which will be ignored...
> E00 Compressed ASCII found. Will uncompress first...
> ...converted to Arc Coverage in current directory
> Importing areas...
> ERROR: Cannot open data source: aveanrfl
> An error occurred. Stop.
> I get the same area message if I omit the extension .e00 from
> file= aveanrfl.e00
> I attach the first lines of the .e00 file:
> EXP 0 /DUMP/GISDATA/RSAMAPGD.E00
> GRD 2
> 1075 910 1-0.21474836470000E+10
> 0.16667000000000E-01 0.16667000000000E-01
> 0.16091670000000E+02-0.34875030000000E+02
> 0.34008695000000E+02-0.19708060000000E+02
> 403 403 403 403 404
> 405 407 407 408 421
> 420 429 433 439 427
> 433 436 426 428 429
> 432 433 434 447 448
> 448 447 448 464 460
> 459 464 480 472 477
> 482 469 487 494 485
> 490 488 487 496 484
> 479 484 485 472 477
> Any idea how I can import this file?
> Thanks,
> Rainer
> NEW EMAIL ADDRESS AND ADDRESS:
> Rainer.Krug@uct.ac.za <mailto:Rainer.Krug@uct.ac.za>
> RKrug@sun.ac.za <mailto:RKrug@sun.ac.za>
<mailto:RKrug@sun.ac.za> WILL BE
DISCONTINUED END OF
> MARCH
> Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
> Biology (UCT)
> Plant Conservation Unit
> Department of Botany
> University of Cape Town
> Rondebosch 7701
> South Africa
> Tel: +27 - (0)21 650 5776 (w)
> Fax: +27 - (0)86 516 2782
> Fax: +27 - (0)21 650 2440 (w)
> Cell: +27 - (0)83 9479 042
> Skype: RMkrug
> email: Rainer.Krug@uct.ac.za <mailto:Rainer.Krug@uct.ac.za>
<mailto: Rainer.Krug@uct.ac.za <mailto:Rainer.Krug@uct.ac.za>>
> grassuser mailing list
> grassuser@grass.itc.it <mailto:grassuser@grass.itc.it>
> http://grass.itc.it/mailman/listinfo/grassuser
RKrug@sun.ac.za <mailto:RKrug@sun.ac.za> WILL BE DISCONTINUED END OF
MARCH
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
RKrug@sun.ac.za WILL BE DISCONTINUED END OF MARCH
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
Rainer@krugs.de
