I’m trying to import a new-style GeoPDF USGS topo map into an existing GRASS location as a raster layer. I’ve converted the file to a GeoTIFF with gdal_translate and then adjusted to projection using gdalwarp. When I import the GeoTIFF into GRASS, each color band is written as a separate layer:
r.in.gdal input=/Users/dkindem/MI_Grand_Haven_20110923_TM_geo_wgs.tif output=MI_Grand_Haven_20110923_TM_geo_wgs
Projection of input dataset and current location appear to match
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.red> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.green> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.blue> created.
(Sun Aug 19 10:50:07 2012) Command finished (2 sec)
Each layer displays (in monochrome), but I’d like to create a single, color, layer.
I’m curious to know if others have encountered this, or have thoughts on the issue.
Þann sunnudagur 19 Augúst 2012 15:00 GMT, skrifaði Dave Kindem <dkindem@gmail.com>:
Hello,
I'm trying to import a new-style GeoPDF USGS topo map into an existing GRASS location as a raster layer. I've converted the file to a GeoTIFF with gdal_translate and then adjusted to projection using gdalwarp. When I import the GeoTIFF into GRASS, each color band is written as a separate layer:
Each layer displays (in monochrome), but I'd like to create a single, color, layer.
I'm curious to know if others have encountered this, or have thoughts on the issue.
