[GRASS-user] Importing From GeoPDF
If you have 3 red, green, blue channels, you can combine them to display using d.rgb (under the special raster menu button in the layer manager) or combine them into a single color map using r.composite.
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 19, 2012, at 12:00 PM, <grass-user-request@lists.osgeo.org>
wrote:
Subject: [GRASS-user] Importing From GeoPDF
Date: August 19, 2012 8:00:21 AM MST
To: <grass-user@lists.osgeo.org>
Hello,
I’m trying to import a new-style GeoPDF USGS topo map into an existing GRASS location as a raster layer. I’ve converted the file to a GeoTIFF with gdal_translate and then adjusted to projection using gdalwarp. When I import the GeoTIFF into GRASS, each color band is written as a separate layer:
r.in.gdal input=/Users/dkindem/MI_Grand_Haven_20110923_TM_geo_wgs.tif output=MI_Grand_Haven_20110923_TM_geo_wgs
Projection of input dataset and current location appear to match
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.red> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.green> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.blue> created.
(Sun Aug 19 10:50:07 2012) Command finished (2 sec)
Each layer displays (in monochrome), but I’d like to create a single, color, layer.
I’m curious to know if others have encountered this, or have thoughts on the issue.
Thanks in advance,
Dave
Dave Kindem
Grand Haven, MI
Thanks.
R. composite seems like the best approach here.
Dave
Dave Kindem
dkindem@gmail.com
616.402.0864
Michael
C. Michael Barton
Hello,
Thanks in advance,
Dave
Dave Kindem
Grand Haven, MI
