I got some Mapinfo vector data with Greek characters in both the attribute column names and the attribute row strings. Initially, both in GRASS and QGIS the characters appear messy. I verified, inside QGIS, that the encoding in question is "cp1253" [0]. Passing this while importing the data in GRASS, like
v.in.ogr dsn=Roads.TAB out=roads encoding=cp1253 --o
does not work though (using ogrinfo --version, GDAL 1.10.1, released 2013/08/26). Is there a proper encoding instruction to pass to v.in.ogr, other than "cp1253"? I want to avoid solving this externally.
Nikos
[0] https://en.wikipedia.org/wiki/Windows-1253
That should be windows-1253
v.in.ogr dsn=Roads.TAB out=roads encoding=windows-1253 --o
does not work either.
Nikos
in the layer manager, menu “Settings” / then “preferences”, tab “attribute”, there is a field to specify encoding for data => this does not change the encoding of the data, but the encoding used to display it …
Sylvain
2014-06-12 17:12 GMT+02:00 Nikos Alexandris <nik@nikosalexandris.net>:
I got some Mapinfo vector data with Greek characters in both the attribute column names and the attribute row strings. Initially, both in GRASS and QGIS the characters appear messy. I verified, inside QGIS, that the encoding in question is “cp1253” [0]. Passing this while importing the data in GRASS, like
does not work though (using ogrinfo --version, GDAL 1.10.1, released 2013/08/26). Is there a proper encoding instruction to pass to v.in.ogr, other than “cp1253”? I want to avoid solving this externally.
Nikos
grass-user mailing list
grass-user@lists.osgeo.org
