[GRASS-user] Importing Mapinfo files with encoding "cp1253'
Sylvain Maillard wrote:
in the layer manager, menu "Settings" / then "preferences", tab
"attribute", there is a field to specify encoding for data => this does not
change the encoding of the data, but the encoding used to display it ...
I have imported the data set in QGIS, changed there the encoding to windows-1253 (Layer Properties > General (Tab) > Data source encoding) and viewed greek names properly. Saving the layer as a Shapefile and defining the encoding to be anything (!?), e.g. "System" or "UTF8" or "Windows-1253" seems to do the trick! Greek names appear, then, as expected in QGIS, in the shell via ogrinfo as well as in GRASS' shell.
The original Mapinfo file:
ogrinfo Roads.TAB -al |grep REGION |head -2
REGION: String (40.0)
   REGION (String) = �������
Importing the (above) file in GRASS and going through the way you suggested, doesn't help. Importing this in QGIS (by setting the encoding to Windows-1253 in the import dialog!), then exported as Mapinfo file:
ogrinfo Roads_QGIS_Exported.tab -al |grep REGION |head -2
   REGION (String) = Τρίκαλα
The same Mapinfo file exported as ESRI Shapefile (with any of the above mentioned encoding) work fine as well. The only difference I can spot between the two Mapinfo files is:
diff Roads/Roads.TAB Roads_QGIS_Exported/Roads_QGIS_Exported.tab
2,3c2,3
< !version 550
< !charset WindowsGreek
!version 300
!charset Neutral
Anyhow, the question is how to do this using GRASS directly.
Thank you Sylvain, Nikos
Nikos
