[GRASS-user] importing maps with non-supported projection system
I need to import some shapefiles that are in a different projection from my mapset. I wish I could do that directly, i.e. that the maps could pe projected to my location as they were imported (for example, if v.proj worked also for non-GRASS maps, as long as they came with georrefering information). But as I understand, I have to create a new mapset and a new location with the projection information of those external maps, import them there, then switch to my mapset and run v.proj from here.
The problem is I don’t have all the information I need to create the location for those shapefiles, or the projection information is not supported by GRASS (I can’t find any similar option when creating a location from QGIS).
Is there any way to import a map, automatically creating a new GRASS location matching the georreferencing information contained in that map?
Thanks a lot,
Marcia
A. Márcia BARBOSA
Department of Biological Sciences
Imperial College London, Silwood Park Campus
Ascot, Berkshire SL5 7PY
UNITED KINGDOM
Unidade de Macroecologia e Conservação
CEA – Universidade de Évora, Pólo da Mitra
7002-554 Évora
PORTUGAL
On 05/12/08 15:04, Barbosa, A. Marcia wrote:
The problem is I don't have all the information I need to create the location for those shapefiles, or the projection information is not supported by GRASS (I can't find any similar option when creating a location from QGIS).
v.in.ogr ... location=
But this only works if your shapefiles are accompanied by *.prj files containing the projection info. If not, then the only way to find that info is either with the source of the data, or by an educated guess looking at the coordinates (i.e. if you see coordinates between 0-90, then you can be pretty sure they are degrees of a lat-long system, although you still won't know the datum used).
Moritz
