I was trying to import Mars DEM with r.in.gdal, and it takes forever
to finish it (It showed 3% after 10 minutes). This is what gdalinfo
says:
gdalinfo /tmp/ESP_035583_2060_RED.JP2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: /tmp/ESP_035583_2060_RED.JP2
/tmp/ESP_035583_2060_RED.JP2.aux.xml
Size is 13094, 26340
Coordinate System is:
PROJCS["Equirectangular MARS",
GEOGCS["GCS_MARS",
DATUM["unknown",
SPHEROID["unnamed",3392593.6110435,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Equirectangular"],
PARAMETER["latitude_of_origin",25],
PARAMETER["central_meridian",180],
PARAMETER["standard_parallel_1",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (3889293.250000000000000,1519463.750000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Corner Coordinates:
Upper Left ( 3889293.250, 1519463.750) (114d18'56.57"W, 50d39'41.21"N)
Lower Left ( 3889293.250, 1506293.750) (114d18'56.57"W, 50d26'20.49"N)
Upper Right ( 3895840.250, 1519463.750) (114d12'18.52"W, 50d39'41.21"N)
Lower Right ( 3895840.250, 1506293.750) (114d12'18.52"W, 50d26'20.49"N)
Center ( 3892566.750, 1512878.750) (114d15'37.55"W, 50d33' 0.85"N)
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
Overviews: 6547x13170, 3273x6585, 1636x3292, 818x1646, 409x823,
204x411, 102x205
Overviews: arbitrary
Image Structure Metadata:
NBITS=10
GRASS location was created from this file:
projection: 99 (Equirectangular MARS)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: a=3392593.6110435 es=0
north: 1519463.75
south: 1506293.75
west: 3889293.25
east: 3895840.25
nsres: 0.5
ewres: 0.5
rows: 26340
cols: 13094
cells: 344895960
I tried to open it in QGIS and it appeared instantly. Then, I tried to
export it from QGIS as Geotiff, but that took again very long (I
didn't wait for it to finish). Running gdal_translate in command line
can't finish either. I tried to debug r.in.gdal and it seems to be
stuck on line 1103 in GDALRasterIO call. Any advice? I can send the
data privately.
Thank you,
Anna
