Hello,
I am trying to import ASCII files with v.in.ascii for subsequent interpolation via v.surf.idw. The problem is that if I put NULL for missing values, v.in.ascii complains about the column being of type DOUBLE and fails. On the other hand if I put missing values as just '', as suggested at
http://www.intevation.de/rt/webrt?serial_num=2763&display=History
then v.surf.rst seems to use those missing values as ZERO values in computing the weighted average.
I tried with something like
v.db.update map=myMap column=myColumn value="NULL" \
where=myColumn=''
But it did not work.
Does anybody have a way around this?
Luigi
On Tuesday 14 November 2006 18:40, Luigi Ponti wrote:
Hello,
as suggested at
where=myColumn=''
Luigi
hi.
how about this:
1. change any nodata values in your input file to an empty string
2. v.in.ascii in=infile sep=sep ... out=outvect
3. double check that the nodata values were imported correctly, i.e missing
from the attribute table
4. v.extract in=outvect where="column = ..." out=vect_no_null
5. v.surf.idw vect_no_null
note that depending on the DB backend you are using, you may need to tweak the
above. another approach might be to code your nodata values as -9999999 or
something like that, and then use that to select only features with 'real'
data.
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Hello,
as suggested at
where=myColumn=''
Luigi
hi.
how about this:
1. change any nodata values in your input file to an empty string 2. v.in.ascii in=infile sep=sep ... out=outvect
3. double check that the nodata values were imported correctly, i.e missing from the attribute table
note that depending on the DB backend you are using, you may need to tweak the above. another approach might be to code your nodata values as -9999999 or something like that, and then use that to select only features with 'real' data.
cheers,
Thanks Dylan!
The -9999999 approach works like beauty.
Luigi
