[GRASS-user] Importing multiple files with r.in.xyz
I'm working with WinGRASS 6.4RC6 on Win XP.
I'm following the steps at http://grass.osgeo.org/wiki/Import_XYZ to
import hundreds files containing TRMM rainfall data.
When I try to follow the instruction:
Just amend above procedure to use wildcards. Change in above example
all occurencies of
cat VTL2733.XYZ | ...
to
cat *.XYZ | ...
and use a more reasonable output name of course. That's all to import
even thousands of files (tiled DEM) easily.
Not sure what a 'reasonable output name is', so I run it as shown
below and get the following error:
cat F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\*.txt| r.in.xyz
-s in=- fs=, out=test
cat: F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\*.txt: No such
file or directory
If I try it with one file only, it works:
cat F:\Hanlie\UCT\M.Sc.\Data\TRMM\2000\02_Februrarie\3B42.000201.0.6.nc.lieb.txt|
r.in.xyz -s in=- fs=, out=test
Range:
x: -28.625000 -27.375000
y: 28.125000 28.625000
z: 0.000000 0.000000
How do I get this to work? And how would I get the output filenames to
be related to the input filenames? For example, if the input filename
is 3B42.000201.0.6.nc.lieb.txt, then I want the output raster to be
named '3B42.000201.0.6'.
Thanks
Hanlie
Hanile
Try this:
1- Install Paths:
http://www.textpad.com/add-ons/files/utilities/paths.zip
It's a useful tool to copy the path and filenames in windows. It adds a
function to rightclick: Pathcopy. You can select all your rasters and
rightclick to copy the paths:
Paste them in a text file
c:\example\raster1.xyz
c:\example\raster2.xyz
2- change them to something like this (use find/replace..macros, etc:)
r.in.xyz -s -g input="c:\example\raster1.xyz" output=raster1 > tmpRegion
SET /p myregion= < tmpRegion
DEL tmpRegion
g.region %myregion%
r.in.xyz --overwrite input="c:\example\raster1.xyz" output=raster1 fs=,
3- Save that as a import.bat
4- From the Start menu, run Grass in Txt mode, change directory to the
folder where import.bat is
5- import.bat
If you google around you should be able to make the script a bit smarter
using DOS and loop (http://www.robvanderwoude.com/ntfor.php).
In linux for example you can shrink it to something like this:
cat list_of_files.txt | while read line; do
    echo $line+"Being processed" # or whaterver you want to do with the
$line variable
raster=$line
r.in.xyz -s -g input=$line output=$line > tmpRegion
myregion= ""`head -n 1 tmpRegion`"
g.region $myregion
r.in.xyz --overwrite input=$line output=$line fs=,
done
and your list_of_files.txt is
raster1
raster2
Hope that helps
Saber
On Tue, 2010-08-10 at 14:59 +0200, Hanlie Pretorius wrote:
all occurencies of
to
cat *.XYZ | ...
file or directory
Range:
Thanks
Hanlie
grass-user mailing list
grass-user@lists.osgeo.org
file or directory
No window$ user here but I think it has to do with the "*.txt" part. How do
wildcard patterns work in these cases (under window$) might be the question to
the answer you are looking for.
Building a for loop to treat one file at a time should do it. In pseudo-code
or in bash this would look like (given all and only .txt files of interest are
in a (the current) directory) :
for FILE in *.txt ; do
    <whatever has to be done for one file! + removing unwanted parts of the
filename using string manipulation tools such as "tr" and "cut">
done
How would this work in windows? Look in past threads, there must be something
or wait till the experts chime-in. Sorry for the indirect answers.
Cheers, Nikos
Thanks for the suggestions.
I think I'm going to try the Linux version as soon as I can get to a
Linux machine.
2010/8/10, Saber Razmjooei <razmjooeis@faunalia.co.uk>:
Hanile
Try this:
1- Install Paths:
DEL tmpRegion
g.region %myregion%
5- import.bat
$line variable
raster=$line
g.region $myregion
done
raster1
raster2
Hope that helps
Saber
all occurencies of
to
cat *.XYZ | ...
file or directory
cat
Range:
Thanks
Hanlie
Linux machine.
You could also try out osgeo live-cd/dvd's (e.g. <http://live.osgeo.org/&gt;\) or
give (some) Linux(-distro) the chance (it deserves) even via virtualbox for
example.
Nikos
My apologies for my ignorance, but how do I get this to run in Linux?
Am using Ubuntu 10.04 and GRASS 6.4RC6.
I entered the following into the GRASS text window and am testing it
with a list of two files (I removed the region settings because the
files all have the same region, which I have already set):
GRASS 6.4.0RC6 (world_wgs84):~ > cat lieb_files_test.txt
3B42.000201.12.6.nc.lieb.txt
3B42.000201.15.6.nc.lieb.txt
GRASS 6.4.0RC6 (world_wgs84):~ > cat lieb_files_test.txt | while read line; do
echo $line+" being processed"
raster=${$line:(-12)} # cut ".nc.lieb.txt" from raster name
r.in.xyz --overwrite input=$line output=raster method="mean" type="FCELL" fs=, x=2 y=1 z=3
As you can see, when I press enter after the r.in.xyz line, I just get
another prompt.
Am I supposed to save it to a separate file and run this as a script?
If so, where should I put this script?
$line variable
raster=$line
g.region $myregion
done
raster1
raster2
Hope that helps
Saber
Hi, short intrusion in this current thread, without knowing exactly what
it is related to : I only mean to suggest you to close the while loop...
This prompt ">" means the shell expects the end of your statement ; here
you should type "done" to close the while instruction.
Hope it helps,
Regards.
Vincent
another prompt.
> $line variable
> raster=$line
> g.region $myregion
> done
> raster1
> raster2
> Hope that helps
> Saber
Samber's method will surely work, but you might more simply try as follows:
# start grass in a location which matches the txt file data
# change to the directory where your txt files are, then do
for infile in *.txt; do outrast=`basename ${infile} .txt`; r.in.xyz in=${infile} out=${outrast} fs=,; done
# that's it :wink:
Micha
GRASS 6.4.0RC6 (world_wgs84):~> cat lieb_files_test.txt
GRASS 6.4.0RC6 (world_wgs84):~> cat lieb_files_test.txt | while read line; do
another prompt.
2010/8/10, Saber Razmjooei<razmjooeis@faunalia.co.uk>:
$line variable
  raster=$line
  r.in.xyz -s -g input=$line output=$line> tmpRegion
g.region $myregion
done
raster1
raster2
Hope that helps
Saber
This mail was received via Mail-SeCure System.
Oops- I forgot the x=2 y=1 z=3 parameters. Add those to the grass command also...
# that's it :wink:
Micha
another prompt.
$line variable
  raster=$line
g.region $myregion
done
raster1
raster2
Hope that helps
Saber
2010/8/11, Vincent Bain <bain@toraval.fr>:
Adding 'done' worked and I got the script running from the command line.
Thanks to everyone who chipped in.
Open gedit (from Accessories) and copy paste the the commands into it.
Save the file to the same location as your raster and your files.txt file
call it import_xyz.sh
Now, open grass from terminal
Once in grass environment...change directory to your file
sh import_xyz.sh
Saber
follows:
# that's it :wink:
Micha
line; do
another prompt.
the
$line variable
  raster=$line
g.region $myregion
done
raster1
raster2
Hope that helps
Saber
2010/8/11, Micha Silver <micha@arava.co.il>:
This works nicely, except that my input files have names like:
3B42.000201.3.6.nc.lieb.txt
and I want the output rasters to be named
3B42.000201.0.6
3B42.000201.3.6
In fact, it would be best if they could be named:
0201.0.6
0201.3.6
I'm struggling with this string manipulation in the shell scripting language.
# that's it :wink:
Micha
> follows:
3B42.000201.0.6
3B42.000201.3.6
0201.0.6
0201.3.6
language.
Try the following (note the backticks in the beginning before "echo" and in
the end as well):
output=`echo "${infile}" | cut -d"." -f2,3,4 | sed 's/^00//'`
Nikos
2010/8/11, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
> follows:
3B42.000201.0.6
3B42.000201.3.6
0201.0.6
0201.3.6
language.
the end as well):
Yes, this worked :slight_smile: Thanks.
Nikos
3B42.000201.0.6
3B42.000201.3.6
0201.0.6
0201.3.6
In bash, you could do:
for infile in *.txt ; do r.in.xyz in=${infile} out=${infile:7:8} ... ; done
Hermann
