[GRASS-user] Importing multiple files with r.in.xyz
I'm working with WinGRASS 6.4RC6 on Win XP
please try also the latest nightly builds of WinGrass64svn (http://josef.fsv.cvut.cz/wingrass/grass64/),
because release candidate 6 of Grass64 is now a little bit outdated.
best regards
Helmut
___________________________________________________________
Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
Thanks for the reply. I'll try that if I don't manage with the Linux version.
However, previously when I worked with the SVN version, I was advised
to rather use the stable version.
2010/8/10, Helmut Kudrnovsky <hellik@web.de>:
best regards
Helmut
Hanlie
You might find this useful:
http://www.surfaces.co.il/?p=578
It's in qgis, but still you can use GRASS plugin to interact with your
datasets.
Saber
version.
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
Had a look at the article. Interesting process.
However, the TRMM rainfall data is already spatially distributed,
albeit at a coarse resolution (0.25 degrees).
2010/8/11, razmjooeis@faunalia.co.uk <razmjooeis@faunalia.co.uk>:
Hanlie
datasets.
Saber
version.
best regards
Helmut
Hello Hanlie:
First I must thank Saber for pointing you to my blog.
Regarding your r.in.xyz question, If you decide to make the jump to Linux, then the scripting capabilities in a bash shell will give you a real "eye-opener". As others have mentioned, you can loop thru a whole directory of files and run a grass command for each with something like:
for infile in *.txt; do
     # get the base name of the txt file without the .txt extension
     # Note that the 2nd parameter for basename includes the dot '.'
     outrast=`basename ${infile} .txt`
     r.in.xyz -s in=${infile} fs=, out=${outrast}
done
I'm sure it's doable also in a windows cmd shell. And there are other ways to get the list of files into a loop. If you'd like to see a sample, check this older blog post:
http://www.surfaces.co.il/?p=241
Micha
On 11/08/2010 12:16, razmjooeis@faunalia.co.uk wrote:
Hanlie
datasets.
Saber
version.
2010/8/10, Helmut Kudrnovsky<hellik@web.de>:
best regards
Helmut
This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
Von: Hanlie Pretorius
Gesendet: 11.08.2010 08:36:01
An: Helmut Kudrnovsky
Betreff: Re: Importing multiple files with r.in.xyz
Grass64svn is the stable version of Grass (compare information in http://grass.osgeo.org/gdp/manuals.php),
of which the official grass64 should be released pretty soon. a release candidate of grass64 is something like a snapshot of grass64svn.
Grass65svn and Grass70 are the both development lines of grass.
best regards
Helmut
WEB.DE DSL SOMMER-SPECIAL: Surf & Phone Flat 16.000 für
nur 19,99 ¿/mtl.!* http://web.de/DSL-Doppel-Flatrate/
