[GRASS-user] Importing Point-Cloud with v.in.lidar
Hello grass-community,
Actually I’m working for a research project (master thesis) with point data, that were exported from dronedeploy one year ago.
Unfortunately processing the exported LAS-files is quit challenging, as there are some issues with the file format (e.g. the projection).
My aim is to import the data into Grass-GIS to process it there with the 3D-fragmentation tool. But till now I was not able to import it… So I thought I’ll ask for some help here.
I tried to process the data with several tools, like lidR package in R-Studio and LAStools. First I had to change the projection with las2las to a appropriate (EPSG 3116) one, to be able to display it correctly in these tools. Now I can do further processing with the data, like creating grids. By the way, these grids are located correctly when loading them to a GIS-application. So coordinates seem to be correctly. Anyway loading the point-data to Grass-GIS (with v.in.lidar tool) fails, because the points are in a wrong location/projection. I did not use -r (limit to current region), so this can not be the problem. First it did calculate something and added a vector map that seemed to be empty, because there was nothing displayed.
Actually it doesn’t even start calculating and there is no vector map produced. I copied the output below. I already got the hint to try importing a ASCII text by converting the LAS file with PDAL. So I will try installing PDAL on my PC. Anyway, maybe some has a solution for the v.in.lidar problem.
Output:
QGIS version: 3.10.2-A Coruña
QGIS code revision: d4cd3cfe5a
Qt version: 5.11.2
GDAL version: 3.0.4
GEOS version: 3.8.0-CAPI-1.13.1
PROJ version: Rel. 6.3.0, January 1st, 2020
Processing algorithm…
Algorithm 'v.in.lidar' starting…
Input parameters:
{ '-b' : False, '-c' : False, '-t' : False, 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : '1209933.8649246846,1210526.7738715957,820900.5310786865,821470.5180333158 [EPSG:3116]', 'GRASS_VECTOR_DSCO' : '', 'GRASS_VECTOR_EXPORT_NOCAT' : True, 'GRASS_VECTOR_LCO' : '', 'class_filter' : '', 'input' : 'C:\\Users\\oc\\OneDrive - HH Gruppe\\Dokumente\\Uni\\Master\\Daten\\Daten_Stuktur\\points\\110_1.las', 'limit' : None, 'offset' : None, 'output' : 'TEMPORARY_OUTPUT', 'preserve' : None, 'return_filter' : , 'skip' : None, 'spatial' : None, 'zrange' : [nan,nan] }
g.proj -c proj4="+proj=tmerc +lat_0=4.59620041666667 +lon_0=-74.0775079166667 +k=1 +x_0=1000000 +y_0=1000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
g.region n=821470.5180333158 s=820900.5310786865 e=1210526.7738715957 w=1209933.8649246846
v.in.lidar -o input="C:\Users\oc\OneDrive - HH Gruppe\Dokumente\Uni\Master\Daten\Daten_Stuktur\points\110_1.las" output=output2221d86f3dd44a7c84ead4bac980f243 --overwrite
v.out.ogr type="auto" input="output2221d86f3dd44a7c84ead4bac980f243" output="C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\cc8523d5d751483b9922084e16845571\output.gpkg" format="GPKG" -c --overwrite
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files...
Executing <C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\grassdata\grass_batch_job.cmd> ...
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>chcp 1252 1>NUL
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>g.proj -c proj4="+proj=tmerc +lat_0=4.59620041666667 +lon_0=-74.0775079166667 +k=1 +x_0=1000000 +y_0=1000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default
Projection information updated
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>g.region n=821470.5180333158 s=820900.5310786865 e=1210526.7738715957 w=1209933.8649246846
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>v.in.lidar -o input="C:\Users\oc\OneDrive - HH Gruppe\Dokumente\Uni\Master\Daten\Daten_Stuktur\points\110_1.las" output=output2221d86f3dd44a7c84ead4bac980f243 --overwrite
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>v.out.ogr type="auto" input="output2221d86f3dd44a7c84ead4bac980f243" output="C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\cc8523d5d751483b9922084e16845571\output.gpkg" format="GPKG" -c --overwrite
ERROR: Vector map <output2221d86f3dd44a7c84ead4bac980f243> not found
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>exit
Execution of <C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\grassdata\grass_batch_job.cmd> finished.
Drücken Sie eine beliebige Taste . . .
Execution completed in 13.86 seconds
Results:
{'output': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding': 'System'}}>}
Loading resulting layers
The following layers were not correctly generated.<ul><li>C:\Users\oc\AppData\Local\Temp/processing_073544cf878b4dd8b5311a6a5d27abcc/cc8523d5d751483b9922084e16845571/output.gpkg</li></ul>You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the algorithm.
Kind regards, Olivier Canon
Hello,
just Need to add a realisation: Maybe the problem is the space in the direction. I already tried loading the input file from direction without space, but it didn’t solve the problem. So I thought it must be something else.
But now I learned that Gis has in general problems with spaces in filenames, so I will first try undo the connection with the Cloud, to evoid the spaces in all directories.
I thought to safe my data this way would be a good idea, but seems not to be the best solution…
Output:
Qt version: 5.11.2
GDAL version: 3.0.4
Input parameters:
Results:
grass-user mailing list
grass-user@lists.osgeo.org
Hi Olivier,
when dealing with not so easy to handle input data, I recommend to use the tools to handle these data directly instead of some interface like QGIS or GRASS GIS that might hide some important information. For raster data, this would be gdalinfo, for vector data ogrinfo, for point clouds lasinfo or pdal info.
If you want to import geodata to GRASS GIS, the safest way is to first create a GRASS location using the CRS of the input data. The CRS of the input data can be obtained with the appropriate *info tool. Then you can import the data. If import does not succeed, the error messages should explain why import failed.
For regular raster or vector geodata recognized by GDAL/OGR, using GRASS GIS via QGIS should work. But point clouds are not always recognized by OGR and not as easy to handle, in which case you need to use other tools than OGR. It also depends on what you want to do with these point clouds.
Markus M
On Wed, Feb 12, 2020 at 5:30 PM <Olivier.C.Canon@umwelt.uni-giessen.de> wrote:
displayed.
Output:
Qt version: 5.11.2
GDAL version: 3.0.4
Algorithm ‘v.in.lidar’ starting…
Input parameters:
{ ‘-b’ : False, ‘-c’ : False, ‘-t’ : False,
‘GRASS_OUTPUT_TYPE_PARAMETER’ : 0, ‘GRASS_REGION_PARAMETER’ :
‘1209933.8649246846,1210526.7738715957,820900.5310786865,821470.5180333158
[EPSG:3116]’, ‘GRASS_VECTOR_DSCO’ : ‘’, ‘GRASS_VECTOR_EXPORT_NOCAT’ :
True, ‘GRASS_VECTOR_LCO’ : ‘’, ‘class_filter’ : ‘’, ‘input’ :
‘C:\Users\oc\OneDrive - HH
Gruppe\Dokumente\Uni\Master\Daten\Daten_Stuktur\points\110_1.las’,
‘limit’ : None, ‘offset’ : None, ‘output’ : ‘TEMPORARY_OUTPUT’,
‘preserve’ : None, ‘return_filter’ : , ‘skip’ : None, ‘spatial’ :
None, ‘zrange’ : [nan,nan] }
g.proj -c proj4=“+proj=tmerc +lat_0=4.59620041666667
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs”
v.in.lidar -o input=“C:\Users\oc\OneDrive - HH
Gruppe\Dokumente\Uni\Master\Daten\Daten_Stuktur\points\110_1.las”
v.out.ogr type=“auto” input=“output2221d86f3dd44a7c84ead4bac980f243”
output=“C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\cc8523d5d751483b9922084e16845571\output.gpkg” format=“GPKG” -c
–overwrite
Starting GRASS GIS…
Cleaning up temporary files…
Executing
proj4=“+proj=tmerc +lat_0=4.59620041666667 +lon_0=-74.0775079166667
+units=m +no_defs”
multiple mapsets g.region -d should be run in each to update the
C:\Users\oc\OneDrive - HH Gruppe\Dokumente>v.out.ogr type=“auto”
–overwrite
ERROR: Vector map not found
Execution of
finished.
Results:
{‘output’: <QgsProcessingOutputLayerDefinition
{‘sink’:TEMPORARY_OUTPUT, ‘createOptions’: {‘fileEncoding’: ‘System’}}>}
generated.
  • C:\Users\oc\AppData\Local\Temp/processing_073544cf878b4dd8b5311a6a5d27abcc/cc8523d5d751483b9922084e16845571/output.gpkg
You can check the ‘Log Messages Panel’ in QGIS main window to find more information about the execution of the
algorithm.
