[GRASS-user] importing problem
hi,
I’m trying to import a shape file shp, but I couldn’t do that.
I tried v.in.ogr but there was some problems, even when i tried to create a location it was also a problem
My projection information are as follows:
PROJCS[“PCS_Transverse_Mercator”,GEOGCS[“GCS_Clarke_1866”,DATUM[“D_Clarke_1866”,SPHEROID[“Clarke_1866”,6378206.4,294.9786982]],PRIMEM[“Greenwich”,0],UNIT[“Degree”,0.017453292519943295]],PROJECTION[“Transverse_Mercator”],PARAMETER[“False_Easting”,500000],PARAMETER[“False_Northing”,0],PARAMETER[“Central_Meridian”,-171],PARAMETER[“Scale_Factor”,0.9996],PARAMETER[“Latitude_Of_Origin”,0],UNIT[“Meter”,1]]
but i couldn’t find the thing called Clarke_1866
I also tried to import .e00 files (the shane problem) but i had the same problem withe Clarke_1866,
If i tried to use an old location and import the data:
for Shane files .e00 noting was displayed because the location was wrong.
I tried g.region vect=“a vector” and it worked.
But my problem was with the shp files where nothing was displayed because the size of the proj file was larger than usual.
Please help me
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us.
hi,
i m trying to import DGN format
but i get the error "area size is1.3e-06 are not imported"
while importing from v.in.ogr
What should i do ?
I'm trying to import a shape file shp, but I couldn't do that.
PROJCS["PCS_Transverse_Mercator",GEOGCS["GCS_Clarke_1866",DATUM["D_Clarke_1866",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-171],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
but i couldn't find the thing called Clarke_1866
I tried g.region vect="a vector" and it worked.
Please help me
      ____________________________________________________________________________________
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us. http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
riad mazloum wrote:
hi,
create a location it was also a problem My projection information are
as follows:
maybe this thread helps:
http://article.gmane.org/gmane.comp.gis.proj-4.devel/1629
http://thread.gmane.org/gmane.comp.gis.proj-4.devel/1616
(shot in the dark)
Hamish
