Hi all, I registered on your list only a few days ago and I love to use grass (newbie though), but I am having a problem importing a geotif raster data. Any clue as to why that is happening? I have pasted the text below. I have tried using the -o flag but I never get the syntax right. Thanks Franz (Wed Mar 10 15:43:05 2010) r.in.gdal input=C:\Users\Franzy\Desktop\Ahafo_prst\tograss.tif output=ahohyehye_class Warning 1: TIFFFetchNormalTag:ASCII value for tag “GeoASCIIParams” does not end in null byte No projection name! Projection parameters likely to be meaningless. Datum not recognised by GRASS and no parameters found ERROR: Projection of dataset does not appear to match current location. Location PROJ_INFO is: name: Universe Transverse Mercator proj: utm datum: wgs84 ellps: wgs84 zone: 30 no_defs: defined Dataset PROJ_INFO is: ellps: wgs84 ERROR: You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset. Consider generating a new location from the input dataset using the ‘location’ parameter. (Wed Mar 10 15:43:06 2010) Command finished (0 sec) |
On Wed, Mar 10, 2010 at 4:49 PM, Franz Okyere <franzzoa77@yahoo.co.uk> wrote:
Thanks
Franz
"GeoASCIIParams" does not end in null byte
Please report the output of
gdalinfo tograss.tif
It seems to be a somewhat tricky GeoTIFF file. Maybe we understand more from
the gdalinfo output.
hi Markus, , gdalinfo report looks fine (I run from command line so I could not paste it) but there seems to be a problem with the projection. The geotiff file is an output from multispec, which is the program I used for a supervised classification so I do not know what the processing did to the file. From the output it seems the projection passed to grass is unknown- the spheroid is unretrievable. Franz — On Wed, 10/3/10, Markus Neteler neteler@osgeo.org wrote: > From: Markus Neteler neteler@osgeo.org > Subject: Re: [GRASS-user] Importing Raster- Newbie > To: “Franz Okyere” franzzoa77@yahoo.co.uk > Cc: “GRASS Users” grass-users@lists.osgeo.org > Date: Wednesday, 10 March, 2010, 19:37 > > On Wed, Mar 10, 2010 at 4:49 PM, Franz Okyere <franzzoa77@yahoo.co.uk> wrote: > > > > Hi all, > > > > I registered on your list only a few days ago and I love to use grass (newbie though), but I am having a problem importing a geotif raster data. Any clue as to why that is happening? I have pasted the text below. I have tried using the -o flag but I never get the syntax right. > > > > Thanks > > > > Franz > > > > (Wed Mar 10 15:43:05 2010) > > r.in.gdal input=C:\Users\Franzy\Desktop\Ahafo_prst\tograss.tif output=ahohyehye_class > > Warning 1: TIFFFetchNormalTag:ASCII value for tag > > “GeoASCIIParams” does not end in null byte > > No projection name! Projection parameters likely to be meaningless. > > Please report the output of > > gdalinfo tograss.tif > > It seems to be a somewhat tricky GeoTIFF file. Maybe we understand more from > the gdalinfo output. > > Markus |
Franz,
On Wed, Mar 10, 2010 at 9:32 PM, Franz Okyere <franzzoa77@yahoo.co.uk> wrote:
hi Markus,
... so the report does not look fine...
Please consider to
- paste the output to http://osgeo.pastebin.com/
- paste a screenshot elsewhere (there are plenty of possibilities in the net
Without this output we won't be able to guess the problem.
supervised classification so I do not know what the processing did to the file.From the output it seems the projection passed to grass is unknown- the spheroid is unretrievable.
This seems to indicate that multispec didn't properly write the metadata
into the file. Or that GRASS does not know the project (unusual but may happen).
