Hello, could someone help me, please? I am rather new in grass, so far I’ve succeeded making basic operations like creating locations, mapsets, importing maps, converting projections, etc. I have downloaded european landuse file which is in TIFF format. Unzipping produced several files, besides the .tiff, with these extensions: .tfw, .aux, .tif.xml, .prj and a .xls file containing a legend. Data in the map are categorical, the legend contains reference of each category to a particular r:g:b color in the map. I successfully imported the map to a new location, where I set projection manually using the g.setproj, using info in .prj file. I displayed the map and it seemed OK. Now, HERE IS MY PROBLEM: I used r.cats to find out what are the categories in the raster file resulting from the .tiff import. It gave me 44 categories from 1 to 44, apparently with no labels attached. I suppose the labels need to be attached somehow manually, although I don’t know how yet. However, the bigger problem seems to be the fact that the .xls legend file contains r:g:b values and I don’t know how to attach them to the 44 categories to the 44 r:g:b values in the .xls legend file. MY QUESTIONS: Is there a way in grass to get information on which color corresponds to which category? How does r.in.ogr use the info contained in files other than .tiff, .tfw, coming in the bundle, or does it use it at all? Jana
View this message in context: Importing .tiff values
