[GRASS-user] importing TIN mesh in GRASS
I have a TIN mesh from a simulation model that I want to bring in the GRASS. I was able to bring in the grid nodes in the vector map but am not sure how to create the triangles. I know GRASS has routines for triangulation, but couldn’t find how to to import a already triangulated mesh.
Would appreciate any help with this.
Jitu
in the vector map
excellent.
run 'g.region vect=grid_point_map' then 'g.region -p' and
then 'g.region -a res=...'. Adjust the resolution so that
the rows x columns is about 2000 x 2000 (adjust for your
needs.
Finally use v.surf.rst to make a surface.
This will be a *huge* improvement over a TIN.
has routines for triangulation, but couldn't find how to to
Generally GRASS doesn't 'do' TINs because it doesn't need to.
It's raster surface engine has traditionally been its strongest
suit, and TINs grew out of a system with a strong vector engine
but a rather weak raster engine. i.e. they are a quick & dirty
kludge to compensate for lack of a strong raster engine. (ie
being able to efficiently handle massive grids on the fly)
none the less if you really want them have a look in the wiki &
addons, you might find some TIN tools there if you really want
them. see also the v.delaunay module for triangulation code.
Hamish
