Hi GRASS list,
I'm trying to import some vectors and use them to look up values on a raster using v.what.rast. I'm using GRASS 7.0.3. I'm getting the error,
No features of type (point) found in vector map <wells>
Which is un-googleable, but implies that my vector db doesn't have points. I'm creating the vector like this:
v.in.ascii --o format=point input=lon_lat_x_y_depth_id.csv output=wells separator=, x=3 y=4 z=0 cat=6 skip=1 columns="lon double precision, lat double precision, x double precision, y double precision, z double precision, id"
db.select table=wells | head
lon|lat|x|y|z|id|L1
-80.648|25.21|1754704.77|-1225843.51|12.77|251241080385301|
-80.566|25.321|1760685.92|-1211916.08|59|251922080340701|
-80.566|25.338|1760275.96|-1210078.02|38|252007080335701|
v.db.addcolumn map=wells column="L1 double precision"
v.what.rast map=wells raster=L130 column=L1
It seems like wells should be imported as point from v.in.ascii. I've tried "forcing" it with "format=point". I've tried converting after import with v.to.point. Nothing has worked yet.
-k.
On Wed, Jun 1, 2016 at 5:49 PM, Ken Mankoff <mankoff@gmail.com> wrote:
Hi GRASS list,
lon|lat|x|y|z|id|L1
what does v.info say?
Anna
-k.
grass-user mailing list
grass-user@lists.osgeo.org
| Mapset: WellsInL1 |
| Database: /projects/USGW_Model/grass |
| Title: |
| Map scale: 1:1 |
| Name of creator: mankoff |
| Organization: |
| Source date: Wed Jun 1 17:44:42 2016 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 15149 Number of centroids: 0 |
| Number of lines: 0 Number of boundaries: 0 |
| Number of areas: 0 Number of islands: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: Equidistant Conic |
| N: 1530707.64 S: -1225843.51 |
| E: 2277579.47 W: -2289702.87 |
| Digitization threshold: 0 |
| Comment: |
| Mapset: WellsInL1 |
| Title: |
| Map scale: 1:1 |
| Organization: |
| Map is 3D: No |
| Comment: |
Maybe the points are not in the current computational region?
I considered that, but
d.mon start=wx0
d.rast L130
d.vect wells
And they all show up perfectly on top of each other.
-k.
Another clue: When I try to convert to points with "v.to.points input=wells output=pts --o", I get the following errors (over and over and over again until I C-c):
WARNING: Unable to insert new record: 'insert into pts_2 values ( 25, 0 )'
aDBMI-SQLite driver error:
Error in sqlite3_prepare():
table pts_2 has 3 columns but 2 values were supplied
table C-c C-c
GRASS 7.0.3 (EQDC):~/projects/USGW_wells >
Hi GRASS list,
lon|lat|x|y|z|id|L1
It might be missing category, because based on this:
https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.what.rast/main.c#L207
points without category are skipped.
Best,
Anna
-k.
Hi Anna,
Hi GRASS list,
error,
Yes. If I remove "cat=6" from the "v.in.ascii" command above, it works. I thought that I could assign a category column. No problem, it works for me this way too.
Thank you!
-k.
On Thu, Jun 2, 2016 at 2:20 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Hi GRASS list,
lon|lat|x|y|z|id|L1
The id values in the input are too large, e.g. 251241080385301, this
causes integer overflow, categories will be negative which is invalid,
thus points appear to have no category.
Markus M
Best,
Anna
-k.
On Thu, Jun 2, 2016 at 8:55 AM, Markus Metz
I darkly remember some discussion about the (non)possibility of
catching such issues but don't recall the output.
So: is there a way to inform the user about ID values in the input
being too large?
markusN
